alignment problem for my C230 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-19-2012, 08:58 AM Thread Starter
Date registered: Mar 2011
Vehicle: Mercedes Benz C300 Sports 4matic, Year 2011
Quoted: 6 Post(s)
Unhappy alignment problem for my C230
I have this problem of a dragging pull in my steering especially when I run above 56mph. Thought its an alignment problem so went to the mechanic for alignment. They tried doing the alignment and could not and told me that the inner tire road of the front right is little bent. They showed me that and it was really bent a little.
Do you think this is a serious problem and have to be fixed only by the mercedes dealer repair mechanic? Or it can be done by any mechanic?
Thank you very much.
Its 2006 Mb C230 sports sedan
debargha is offline
post #2 of 3 (permalink) Old 05-19-2012, 09:08 AM
Date registered: Feb 2012
any competent mechanic should be able to replace inner tie rods. If your mechanic can't do it I would probably start looking for a new mechanic.
kered is offline
post #3 of 3 (permalink) Old 05-19-2012, 09:58 AM
Date registered: Nov 2003
Vehicle: 2004 CLK320
Quoted: 5 Post(s)
The left front tie rod of my w209 was replaced by the dealership 2 years ago.
Parts:. $73
Labour: 0.90 hr
You will need an alignment after a tie rod change.
mis3 is offline
    Front Alignment for C230 Komp Kerry Newman W203 C-Class 8 08-13-2011 06:12 AM
    2006 C230 Sport Alignment DMensik W203 C-Class 6 07-17-2009 01:36 PM
    '00 C230 Kompressor rear alignment problem? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 06-10-2008 09:21 PM
    2005 C230 Wheel Alignment... kjhayes007 W203 C-Class 7 02-01-2008 04:03 PM
    06 C230 suspension type 4 alignment miked56 W203 C-Class 5 05-31-2007 05:50 AM
