BAS ETS ABS warning lights on after electrical work. - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-14-2012, 01:40 PM Thread Starter
Date registered: May 2012
Took my ML 270 CDI (W163) to auto electrician to fix problem on lights. He strips the fusebox (??????), many layers of fusebox! Took him 3 days to re assemble it, now as soon as I pull away, the BAS/ETS and ABS lights come on and stay on until I switch off. They do not come on at startup, only when I drive above about 20km/h. Cruise control still operates. Any ideas? Thanks.
BrianEllse is offline
post #2 of 2 (permalink) Old 05-19-2012, 09:06 AM
Date registered: Feb 2012
did he have the battery removed while doing the work?? Try turning the key on and turning the steering wheel from lock to lock a couple of times. This recalibrates the steering angle sensor after a battery change. I don't know if this is your problem but its worth a try.
kered is offline
    Instrument Cluster lights (the 4 2W bulbs) wont work ,warning lights/blinkers do WTF? PKariCL600 W140 S-Class 3 02-19-2012 04:19 AM
    4matic does not work. No warning lights on. Timon W124 E,CE,D,TD Class 3 12-19-2011 01:12 AM
    exterior lamp failure warning - all lights work! PurpleBarney W126 S,SE,SEC,SEL,SD,SDL Class 8 12-19-2009 01:10 AM
    W211 Brake Warning, ESP Warning Lights? willy_manilly W211 E-Class 0 02-16-2009 10:27 PM
    New Electrical Problem: Dash + Instrument Cluster lights do not work! sightless R170 SLK-Class 8 06-17-2008 01:09 AM
