Horn, Turn signal and High beams - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-11-2012, 07:57 PM Thread Starter
Date registered: Dec 2011
Vehicle: 2001 Mercedes E320 4 MATIC
Hi There,
I have a 2001 E320 4Matic, A few days ago my horn stopped working and figured it was a fuse or relay and didn't think much of it. Tonight as I entered the car, I noticed that the right turn signal and high beam indicators were on. I started the car and as soon as I wood use the high beams or use the right turn signal, the engine would die and I would get a Display malfunction error. Turned off everything, waited a bit and restarted the car and was able to drive off no problems, but as soon as i would attempt again with the high beams or turn signal the engine would cut off again. I drove my car home without any issues but its friday night and i'm stuck all wknd without a mechanic, and no one who could scan for codes. Has anyone ever had a similar problem?
vinnymart is offline
    No wipers, high beams or horn - electrical gremlins Craig300cd W123 E,CE,D,CD,TD,TE Class 0 12-12-2011 10:07 AM
    Low beams will not turn on...but high beams do 061405 R170 SLK-Class 2 11-01-2010 09:00 PM
    1999 slk230 horn and high beams not working cpairways R170 SLK-Class 2 11-05-2009 08:36 PM
    Wiper/turn signal/horn assembly on older 460 engnenk G-Class 1 04-08-2007 05:10 AM
    Birger, I got it to work! Bi-Xenon high beams & halogens high beams!!... Drew W163 M-Class 15 06-11-2002 08:00 PM
