20 AMP FUSE FOR TRUNK BLOWS - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-09-2012, 11:53 AM Thread Starter
Date registered: Nov 2011
Vehicle: 2002 cl600
HAVING TROUBLES REPLACE 20 AMP FUSE UNDER SEAT FOR DOOR CLOSER AND TRUNK PULL DOWN ALL DOORS PULL CLOSED WHEN TRUNK OPEN IF I CLOSE TRUNK IT WILL NOT PULL DOWN I NEED TO PUSH IT ALL THE WAY TO LOCK DOWN THEN DOORS DON"T PULL CLOSEDAND FUSE BLOWS ,,NEED TO OPEN TRUNK WITH KEY HAD CHARGER HOOK UP TO CAR WITH TRUNK CLOSED IF CABLE GOT JAMED IN PULL DOWN COULD IT HAVE CAUSED DAMAGE ALL WORKED FINE BEFORE THANKS
BADBENZ500 is offline
post #2 of 3 (permalink) Old 05-12-2012, 07:27 AM
Date registered: Feb 2012
What car is this on?? I know that some vehicles that have a wiring harness running alongside the trunk hinges can become pinched and break. If you have a power feed wire that is shorted to ground it would cause the fuse to blow. Again more info is needed if you want help though
kered is offline
post #3 of 3 (permalink) Old 05-13-2012, 06:33 PM Thread Starter
Vehicle: 2002 cl600
SORRY IT"S 2000 S430 ALL FUNCTIONS WORK OK WITH NEW FUSE AS LONG AS I DON"T CLOSE THE TRUNK WHEN TRUNK IS CLOSED FUSE BLOWS THANKS
    300 SEL fuse 15 blows Brett24 W126 S,SE,SEC,SEL,SD,SDL Class 2 09-15-2010 08:48 PM
    B fuse blows MB_Mike W126 S,SE,SEC,SEL,SD,SDL Class 0 08-16-2010 08:56 AM
    Closing trunk lid blows 20 amp fuse (F 71) M 41 R230 SL-Class 3 08-04-2010 04:03 PM
    fuse blows out MarkyBluntz W126 S,SE,SEC,SEL,SD,SDL Class 3 02-12-2010 09:05 AM
    Fuse 13 blows ricklin R/C107 SL/SLC Class 4 02-06-2006 08:26 AM
