mercedes s class tail lights staying on - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-08-2012, 12:51 PM Thread Starter
Date registered: Dec 2010
Hi to all members,
i have a mercedes s-class that is giving me trouble for the last 4days and i am really stuck with it. wonder if someone can help me. basically the tail lights keeps staying on and the abs light on the cluster stays on as well. as soon as i turn the ignition on and goes off as soon as the ignition is switched off. i have checked all the fuses on the car changed the brake light switch and even changed all the modules from another car to the one i am having trouble with. i even checked the break in the two taillight wires and all seems to be fine tho. so i do not understand what can be the cause of this. BUT when i turn the ignition on and disconnect the small block connector on the ESP control module on the right fusebox the connect which is next to the two CAN cables the light goes out and everything works as normal but abs light still stays on. i had connected my original star diagnostics machine and the faults i get in the ESP module is the stop lamp fault with the fault code c1200 and the other one is c1024 something to do with EIS CAN fault. i hope someone can help me with this issue i am having. thanks in advance.
parmar87 is offline
    FS: 2000 - 2007 Mercedes Benz C Class OEM Tail lights Rich1MB For Sale/Wanted/Trade/Giveaway 3 11-27-2011 12:21 PM
    MERCEDES W126 S CLASS 81-91 EURO SMOKE TAIL LIGHTS - Group Buy ceedee W126 S,SE,SEC,SEL,SD,SDL Class 90 11-15-2007 05:43 PM
    FS Mercedes Benz W220 04 S-Class TAIL LIGHTS autoblz W220 S-Class 16 05-05-2007 07:15 PM
    Those tail lights for a w220 are not unique at all comparing to these S-Class Tail Lights Guest (MBNZ) W220 S-Class 7 06-14-2002 08:17 PM
