c240 Central locking - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-30-2012, 04:47 PM Thread Starter
Date registered: Sep 2010
Is there someway that a person can mimic the frequency of a c240 2001 benz. At work.. When am at work the trunk opens and then when i change the locking system to individual on the remote the driver door unlocks but the trunk still opens... So now I locked the trunk with the Mechanical key I will monitor this.. has anyone seen this issue before where the doors r being uncooked or the trunk opens.... whilst in park and the engine is off no key in the ignition..
Out of all days this happened today whilst it rained all day good thing i took my mac out of the trunk
sannah is offline
post #2 of 5 (permalink) Old 05-01-2012, 10:26 AM
Date registered: Jan 2007
You could have water backing under the wiper motor area that will fill with water if the drains are clogged which will then fill your fusebox with water, this will cause the front Sam to do some crazy things, might be worth checking.
evank001 is offline
post #3 of 5 (permalink) Old 05-01-2012, 03:39 PM Thread Starter
u know i will look into that we had allot of rain here this weekend
sannah is offline
post #4 of 5 (permalink) Old 05-01-2012, 06:59 PM Thread Starter
is there a way to disable it for the night until in the morning
sannah is offline
post #5 of 5 (permalink) Old 05-02-2012, 03:10 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 404 Post(s)
Can you (temporarily) release the (2?) springs that flip up the trunk lid when the lock is released. Then even if the trunk lock pops open, your trunk should stay shut.
Just why this is happening has stumped me....
You might try removing fuse f8 from the trunk fusebox, and see what happens. This will take power from the left/right window antenna amplifiers. You might also lose the radio signal -not sure about that. But it should stop a spurious external signal triggering the CL system.
keyhole is offline
Central locking problem on W221 S-class, Central gateway related? flygrip W221 S-Class 7 11-29-2010 02:53 AM
01 C240 Key/Central Locking problems. Help! stashtrey W203 C-Class 0 01-23-2010 10:08 AM
Central locking problem with 1997 Mercedes C240 - Does not lock or unlock mammsp W202 C-Class 1 01-13-2010 01:44 AM
Central Locking Makes A Machine Gun Like sound When Locking UKML55 General Mercedes-Benz 3 10-20-2008 02:59 PM
Central Locking pump faulty - worth replacing or new locking motors? jpdp.au W210 E-Class 2 11-26-2007 03:03 PM
