Automatic gearbox levels - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-27-2012, 05:00 AM Thread Starter
Date registered: Apr 2012
Red face Automatic gearbox levels
I have a 52 plate CD220 CDI auto and am wondering about the gearbox as recently it stuck in 1st and would not change up. After a short break it self corrected. I've asked a local garage to check its oil level but they've said even with the correct dipstick they could not read it - so, does (like the engine oil) the car have an electronic warning for low levels?
seanxtown is offline
post #2 of 2 (permalink) Old 04-27-2012, 06:09 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 341 Post(s)
sean - Welcome to BW.
Please complete your profile with User CP as you model/year location often helps with answers here. Also work out which forum to use, as there will be one for your model. There is no model CD 220 CDI. It is either a CLK 220 CDI which is a W209, or a C220 CDI which is a W203.
Also please remember that most readers here are in the US, and have no idea how to read a UK number plate to know your year of manufacture.
About your transmission. I do not know what transmission you have. MB offered two types of automatic transmission around that time - the 5-speed 722.6, and the 7-speed 722.9.
The 5-speed can be topped up with ATF via the dipstick tube. The 7-speed cannot, and the procedure is done from under the car, using a special filler.
As ATF is not normally consumed (as is engine oil) MB decided that there is no need on all their transmissions for a level indicator/warning light.
What make you think that you have lost ATF? Any signs of it on the transmission pan? What is your mileage? Has the ATF ever been changed?
About limp-home mode, it generally signifies a transmission 'control' problem, (ie, shift plate) but we recently had a post here from a CDI diesel owner that has this fault associated (indirectly) with a blocked dpf. Ever had a problem with that?
keyhole is online now
    automatic gearbox lukeyboy W210 E-Class 1 11-22-2011 10:53 AM
    W123 automatic gearbox for w124 automatic? electronicsounds W124 E,CE,D,TD Class 5 11-16-2010 08:13 AM
    Automatic gearbox baigais W140 S-Class 2 07-15-2009 08:22 AM
    Automatic gearbox matteus W123 E,CE,D,CD,TD,TE Class 5 03-09-2003 03:29 AM
    automatic gearbox Guest (MBNZ) General Mercedes-Benz 1 03-06-2001 05:43 AM
