2002 S500 Engine Fan wiring T___T HELP - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-26-2012, 12:58 PM Thread Starter
Date registered: Jul 2011
hey guys so I have a 2002 S500 and it would be the biggest help if you guys can help me with this.
So this is the deal, the Benz overheats, I put a new water pump, thermostat, radiator hose, etc. Its all good there, I realized that the Engine FAN does not work, and then I looked into the wiring, and found that 3 wires are cut and not connected, I don't know how to connect them back, here are some links to the images of the wires???
One thin wire is BROWN
the second also thin one is PURPLE BLACK
the third thicker one is RED GREEN
The front drivers side headlight burned in the past and I guess the original owner took it to a place where they did the wiring for it, and didn't connect the fan wires??
When I connect the purple black one to the thick red green one my fan will start at HIGH speed and when I connect the brown one, nothing turns on, I don't know where these wires go or connect, please help !
http://i1100.photobucket.com/albums/...akus/image.jpg
http://i1100.photobucket.com/albums/...kus/image2.jpg
arnak is offline
post #2 of 2 (permalink) Old 04-27-2013, 07:29 PM
Date registered: Mar 2012
Vehicle: 02 CL55 AMG Clone, 99 Ford E150, 16 ft boat
wow that looks like a lot of modification has been done to the wiring. are you talking about the 4 wires that come out of the radiator fan plug? all i can tell you is the brown one is usually a ground on mercedes (or so i've been told)
-02 CL500 to 02 CL55 ///AMG engine/tranny swap, coilover suspension, Lorinser fenders and trunk lip, 2 12" kicker CVR's, 20 inch Giovanna kilis in flat black
check out my band!
ctravis595 is offline
    lower engine wiring harness V8 S500 Merc-S600 W140 S-Class 59 04-08-2013 02:27 AM
    I need wiring harness for 94 S500 yaahoos W140 S-Class 4 02-08-2011 01:24 PM
    95 S500 Wiring Harness Eva89 W140 S-Class 3 04-07-2008 11:21 AM
    2002 Mercedes C32 AMG Kompressor engine, transmission with wiring harness pahasbenz For Sale/Wanted/Trade/Giveaway 2 12-28-2007 11:22 AM
    2000 S500 wiring diaghram Attila a rem W220 S-Class 1 05-01-2004 03:09 AM
