C350 Problems with Washing - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-20-2012, 10:04 AM Thread Starter
Date registered: Mar 2012
Vehicle: 2009 c350
Hello,
I have a c350 and I can't wash it without the sensors locking and unlocking it multiple times.
Is there a way to put it into valet mode or some other temporary feature that will prevent the sensors from picking it up?
Griffer is offline
post #2 of 11 (permalink) Old 04-20-2012, 10:12 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 374 Post(s)
Never heard this one before!
Is this a carwash or are you hand washing? Is this a Keyless Go model? We need a few more details before we start guessing here...
keyhole is online now
post #3 of 11 (permalink) Old 04-20-2012, 10:17 AM Thread Starter
Vehicle: 2009 c350
Sorry!
It is a 2009 model and has keyless go. It happens when I wash it with a pressure washer. It makes sense when I hit the sensors on the door with the water but sometimes it happens when I wash the mirrors as well.
It is really sensitive and repeatedly locks and unlocks.
Thanks for your help.
Griffer is offline
post #4 of 11 (permalink) Old 04-20-2012, 10:39 AM
keyhole's Avatar
Quoted: 374 Post(s)
Aah - that explains it!
Do you have the Owner's Manual? If so there will be a warning under the Chapter about Washing a car with KEYLESS-GO, especially referring the the danger of Power washing that can cause the mis-operation of the door locks. So it is not a fault.
Try cutting down the pressure a tad...
post #5 of 11 (permalink) Old 04-20-2012, 11:07 AM Thread Starter
Vehicle: 2009 c350
Thank you for your help!
Unfortunately every cash wash I've been to only has one pressure level: excessive. I guess I'll have to start breaking out the old sponge and bucket.
Griffer is offline
post #6 of 11 (permalink) Old 04-20-2012, 02:08 PM
jks2007red230's Avatar
Date registered: Feb 2012
Vehicle: 2007 Mercedes-Benz C230, 2007 Chevy Equinox, 2003 Saab 9-3 2.0t, 1996 Chevy Tahoe, 2000 Ranger R83
I would definitely break out the old sponge & bucket. The pressure washers are too harsh. You might as well be sandblasting your car with some of them. Basically what you are doing is scouring the dirt off the paint with water pressure. Two buckets, one sponge. First bucket has soapy water (don't use dishwashing liquid) and second bucket has clean water. Dip the sponge in the soapy water and wash an area. Rinse in the clean water and then redip into soap. If clean water gets too dirty then change it out. Your paint will love you for it.
jks2007red230 is offline
post #7 of 11 (permalink) Old 04-21-2012, 04:45 AM
eric242340's Avatar
Quoted: 296 Post(s)
I do not think the car has a real problem, just does not like pressure washing, however a quick diagnostic test for fault codes may help. When driving the car in heavy rain does it affect anything electronically controled??
ERIC.
eric242340 is offline
post #8 of 11 (permalink) Old 04-21-2012, 06:01 AM
keyhole's Avatar
Quoted: 374 Post(s)
Eric - the OM specifally referred to models with KEYLESS-GO experiencing this problem.
Are their Central Locking sensors different to those of other cars?
post #9 of 11 (permalink) Old 04-21-2012, 06:25 AM
eric242340's Avatar
Quoted: 296 Post(s)
Yes of course the sensors are different, to lock the car requires simple pressure on the handle. If you have the key in your pocket, then simply touch the inside of the handle, you do not need to pull the handle, and the car will unlock. To lock the car simply touch the outside of the door handle and it will lock.
If pressure washing the car, the simple answer is to keep the key well away from the car so the KG will be switched off.
ID:	439712   Click image for larger version
ID:	439713   Click image for larger version
ERIC.
post #10 of 11 (permalink) Old 04-21-2012, 09:15 AM
keyhole's Avatar
Quoted: 374 Post(s)
There's your answer then, Griffer!
    Fog Lights On My W204 C350..Problems the_indian_kid@hotmail.co W204 C-Class 0 10-05-2010 04:35 PM
    car washing day jcmbz W140 S-Class 1 04-11-2010 10:36 AM
    2006 C350 4matic several questions/problems... aarghj W203 C-Class 5 11-21-2009 12:39 PM
    Washing - What do you use? mrbangbam W204 C-Class 10 04-17-2009 05:23 PM
    Washing Benzonline W126 S,SE,SEC,SEL,SD,SDL Class 18 10-23-2003 03:25 AM
