Hi there.another tacho not working on a 190d? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-14-2012, 05:51 PM Thread Starter
Date registered: Apr 2012
Vehicle: Mercedes 190d 2.5 1990
Hi everyone here. I've recently bought myself a reasonably tidy 190d. Done 268000 now but still running strong. I've replaced glow plugs so far and also just replaced the rpm sensor on the bell housing in hope that's fix the gauge not working. Found no.10 fuse was blown put new in.and the rev counter goes right round to the end. Past 7000rpm that is. I pulled the plug off cluster and tested voltage ~ac and came up with about 3.00 touch the accelerator and then it'll drop to 0 and volts ~ drop to about 2.2v~.
I'm now lost on what to do I've printed off heaps to try out but still no joy. Where is the signal being swapped around to opposite. Pulled the ''klima'' relay out and checked it but what do I do with it? I've tested the a/c pump by bridging the pressure sensor and it works ok. So the sensor isn't faulty? The rev gauge still inop correctly.
It's a 190d. 2.5 1990 om602 .w201126.
190dNZ is offline
post #2 of 2 (permalink) Old 04-15-2012, 03:40 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld, here is a link to the forum for your car;
W201 190 Class - Benzworld.org - Mercedes-Benz Discussion Forum
eric242340 is offline
    85 190d AC charged but not working. connorr W201 190-Class 3 04-18-2011 01:18 PM
    Tacho? djinh W123 E,CE,D,CD,TD,TE Class 12 11-13-2009 07:38 AM
    tacho for a 240? iNeon W123 E,CE,D,CD,TD,TE Class 2 05-08-2005 07:47 AM
    tacho in 123 gdbmj W123 E,CE,D,CD,TD,TE Class 13 07-28-2004 03:25 AM
    tacho Paul Burroughes G-Class 3 04-02-2001 04:23 AM
