trans problems not sure where to post - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 04-13-2012, 11:22 AM Thread Starter
Date registered: Apr 2012
2002 clk55 amg. Had a broken shifter shaft. Pulled it off re-welded it and re-installed. Now when I try to drive it won't come out of first gear. The display on the dashboard doesn't work either. Used to say p,r,n,d....now just and empty digital box. Have taken everything apart cleaned connections and re-installed. Please help.
sage_fsu is offline
post #2 of 18 (permalink) Old 04-14-2012, 11:04 PM
Lightbulb
Your shifter goes into an encased housing, which also houses the shifter control unit - the Electronic Selector Module - as one integrated unit. If you welded it, chances are, debris found its way through the slot in the case, onto the circuit board, causing irreparable damage. It sounds like you need a new shifter.
AmStrat10 is offline
post #3 of 18 (permalink) Old 04-15-2012, 03:08 AM
eric242340's Avatar
Quoted: 312 Post(s)
You may have fault codes stored on the EGS, certainly if you opened the ignition whilst the shifter was disconnected, these codes will need to be cleared.
ERIC.
eric242340 is online now
post #4 of 18 (permalink) Old 04-15-2012, 07:25 AM
Clearing faults in the Trans Control Unit will not resolve shift issues....
post #5 of 18 (permalink) Old 04-15-2012, 08:24 AM
eric242340's Avatar
Quoted: 312 Post(s)
Excuse me as I am a mere novice at this. Probably why I have 33k posts, I am still trying to get it right, oh and being a Benz Tech with 30 odd years experience does not help either, maybe I should work on nissan?
ERIC.
post #6 of 18 (permalink) Old 04-15-2012, 08:55 AM
We have a guy at our shop who's been working on MB for 34 years. He can't fix a sandwich...
33k posts? I fail to see the relevance.
Sent from my Autoguide iPhone app
post #7 of 18 (permalink) Old 04-15-2012, 09:10 AM
eric242340's Avatar
Quoted: 312 Post(s)
I am that guy in your mind, you are an apprentice in mine. What you posted about the shifter is correct but you do not wish to view any other opinion and replies to threads work best with many opinions. OK
ERIC.
post #8 of 18 (permalink) Old 04-15-2012, 12:57 PM Thread Starter
Ty for your help. When I welded the shifter I removed it from the housing. I didn't weld it while it was in the car. How would I go about clearing fault codes? And could that be what is keeping the display on the dashboard from showing what gear it is in?
sage_fsu is offline
post #9 of 18 (permalink) Old 04-15-2012, 05:39 PM
Okay, buddy, calm down. You're the man. Oy vey...
post #10 of 18 (permalink) Old 04-15-2012, 05:45 PM
Did you ever disconnect the shifter from the linkage rod (underneath the car, connects the shifter to the transmission) at any time during your repair? If so, it may need to be adjusted, to allow for proper centering of the PRND positions in correspondence to the positions at the transmission. Otherwise, implausible communication between your shifter & transmission can result. Another question: how did the shifter rod break in the first place?
Trans Problems randyfishermusic W210 E-Class 3 02-19-2012 12:21 PM
Trans problems the70rose W201 190-Class 1 03-22-2007 06:41 AM
Trans Problems Hatley535 W126 S,SE,SEC,SEL,SD,SDL Class 0 03-27-2006 10:03 AM
Trans Problems Hatley535 W126 S,SE,SEC,SEL,SD,SDL Class 0 03-27-2006 10:00 AM
Trans problems Guest (MBNZ) W124 E,CE,D,TD Class 5 02-10-2002 11:49 AM
