My Daughter called tonght - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-11-2012, 09:15 PM Thread Starter
Date registered: Apr 2012
She's 2 hours away at school with a 2000 430CLK, she said it was making a "noise", she said it wouldn't shift out of 1st so she pulled over, shut it off then restarted it and it seemed to shift fine except for a low humming noise until it shifted into 3rd gear and then it went away.
Any ideas? Thanks for any help signed Father of College Student
MikeyV is offline
post #2 of 4 (permalink) Old 04-12-2012, 07:16 AM
Musikmann's Avatar
Quoted: 5 Post(s)
There is a dedicated forum for the CLK-Class so you might look there. Scroll down from this general forum until you see the coupes and cabriolets section and look for the W208. But my wildest guess is it sounds transmission related so it might need the control unit scanned.
Musikmann is offline
post #3 of 4 (permalink) Old 04-12-2012, 07:26 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
I suspect transmission is acting up. When, what was the last service done to the car? Was it really cold last night?
Worst case is transmission is going bad, it's costly. However, a simple fix for it may be just some fluid addition. But transmission fluid should not need to be added unless there was leak. Most of us don't look where the car was parked for signals to anticipate car problem caused by leaks. I suggest not to drive the car until someone can check it out,; driving it may worsen the problem. Meanwhile, your can carpool or rent a small car for a week because her MB can stall at any moment unexpected.
W210 forum got great info in the stickies for transmission problem or related problems.
mbvis is offline
post #4 of 4 (permalink) Old 04-14-2012, 12:15 PM
Date registered: Feb 2012
the 722.6 transmission may be leaking at the pilot bushing. You won't see fluid under the vehicle, it will however wick up the wiring harness and into the cabin and short out the transmission control unit. if you pull up the pass footwell carpet ther should be a plate that you can unbolt and the transmission control unit is under the plate. With the key off unplug the unit and see if there is fluid in the harness.
kered is offline
    My Daughter Jack Bauer Off-Topic 43 02-03-2011 02:13 PM
    Why are 190's called 201? Are they called any other number as well? spree17 W201 190-Class 8 05-06-2010 05:00 AM
    In Jakarta 1 place is called Blok M, in Surabaya it is called Dolly Street but in the Jakarta Expat Off-Topic 3 07-09-2009 10:14 AM
    Should I buy this MB for my daughter? spankyway General Mercedes-Benz 28 01-15-2008 09:27 PM
    My Salesman called and I placed my order for the SLK32, but there is a new Designo, called MK... Norb R170 SLK-Class 9 04-03-2001 05:00 AM
