to synth or not to synth? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 04-10-2012, 12:16 PM Thread Starter
Date registered: Dec 2011
Hi here. Gotta 97 E320 with just now 117k miles. car is new to me and runs beautifully. Looks like they have been using reg oil. Should i go to synthetic or not? also best brands? THX GREAT FORUM!!!!!
saint45 is offline
post #2 of 9 (permalink) Old 04-11-2012, 08:18 AM
Date registered: Jul 2004
Quoted: 264 Post(s)
It's entirely up to you - your car is fine with either one. Paying more for oil sometimes helps people with low self esteem feel better about themselves.
deanyel is online now
post #3 of 9 (permalink) Old 04-11-2012, 08:23 AM
jks2007red230's Avatar
Date registered: Feb 2012
Vehicle: 2007 Mercedes-Benz C230, 2007 Chevy Equinox, 2003 Saab 9-3 2.0t, 1996 Chevy Tahoe, 2000 Ranger R83
I use synthetic in all my vehicles. Don't have to worry about sludging of oil in pan. Synthetic is more expensive but I look at it as I paid this much for a vehicle, why wouldn't I pay a little bit more for something that could make my engine last longer.
jks2007red230 is offline
post #4 of 9 (permalink) Old 04-11-2012, 08:49 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
This is how I see the oils.
Non-synth: Oil change every 4K miles.
Synth: Oil change every 8K miles.
The replacement is done before oils break down.
Non-synth, $3/qt. Synth, $6/qt.
So price-wise, synth, non-synth are the same. Non-synth doubles the labor.
Some old car may burn oil. Even some new ones do, too.
Waiting 8K miles to check/replace the oil while relying on the computer to flash "oil level low" warning is just too late, low oil level may already hurt your car engine. Regardless of the oil to use, check its level often.
mbvis is offline
post #5 of 9 (permalink) Old 04-11-2012, 09:56 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Generally speaking, synthetic oils are superior to conventional oils.
But at 117K, what's the benefit in switching? To the extent dino hasn't been protecting the engine, much of the wear has already occurred. There's also the anecdotal evidence of many who have switched only to find that the synthetic finds leak paths that weren't there before.
That said, I'm a fan of synthetics, and if you are as well, then try it. If leaks develop you can always go back to dino. Pick a good brand with the correct viscosity per your manual.
Good luck.
Edit: Mobil1's site recommends their 0W40.
Check Codes is offline
post #6 of 9 (permalink) Old 04-11-2012, 10:31 AM
Kajtek1's Avatar
Quoted: 1068 Post(s)
I am fan of synthetics as well, but Mobil1 has some problems with their oils, that they are trying to sweep under the carpets.
Per my recollection MBUSA changed the policy on oils about 2001 and all cars prior to that run on dino with FSS just fine. Our ML320 was running for 3 years on dino with oil replaced every 18 months at average 12k miles, later switched to synthetics and in 13 years in our family never had any engine problems.
I switched to synthetics in several high mileage vehicles and had positive results like less oil consumption. Even my John Deere tractor runs on synthetic.
Kajtek1 is online now
post #7 of 9 (permalink) Old 04-11-2012, 10:49 AM
Musikmann's Avatar
Quoted: 5 Post(s)
If you know with a reasonable level of certainty your car has always run on dino oil I would stick with it. I have 2 cars (Toyota and Plymouth) both older than yours and with higher mileages. Both have had dino from day one; I had their oils analyzed and they came back good. BTW I have always maintained a 3000 oil/filter interval and use Pennzoil.
Musikmann is offline
post #8 of 9 (permalink) Old 04-11-2012, 08:02 PM
Date registered: Nov 2003
Vehicle: 2004 CLK320
Quoted: 5 Post(s)
I had the last generation Honda Prelude, the one with 200HP. After 100k km, I switched from regular oil to synthetic oil. I then noticed that my car was losing oil and this car never lost oil before. This lasted for a few months and I finally switched back to regular oil and the problem went away.
This was 9-10 years ago and I cannot remember the details but I remember I had to add oil every week or so.
This experience teaches me that if an engine is used to regular oil for a few years, change oil type may cause issues.
mis3 is offline
post #9 of 9 (permalink) Old 04-12-2012, 06:22 PM
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Oil threads, what a great topic!
MTI is offline
    OT - Screaming Synth oil deal Mogasaurus Unimog 2 04-29-2010 03:22 PM
    For shingleback ATF Dex VI synth. Teutone W201 190-Class 0 01-17-2009 02:02 AM
    synth + dino.... = ? cashman W123 E,CE,D,CD,TD,TE Class 7 09-12-2007 07:50 PM
    Synth vs. dino oil onesixthree W163 M-Class 10 09-27-2006 05:13 PM
    What oil is better: castrol synth. or mobil synth? Guest (MBNZ) W203 C-Class 5 10-19-2001 12:20 AM
