Relay Locations - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-10-2012, 12:19 PM Thread Starter
Date registered: Apr 2012
Relay Locations
I just joined this forum and have tried to search for an answer but I can't even find my C280 in the "Jump to forum" selection. Can someone please answer this question!!
I have applied 12 V directly to the fan and it runs at high speed ok.
I have measured the voltage at the connector (disconnected) and it only measures 1 volt even with the AC turned on.
I supect a fuse or relay.
[B]Where are the cooling fan relays located in my C280?
Thanks DJ
Doris Moore is offline
post #2 of 3 (permalink) Old 04-14-2012, 01:28 PM
Date registered: Feb 2012
YOU NEED TO SUPPLY MORE INFORMATION!
What year is the vehicle?
kered is offline
post #3 of 3 (permalink) Old 04-14-2012, 11:59 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Unlikely a fuse or a relay anyway, more likely a regulator (or a resistor if it is an older C-class).
Diesel Benz is offline
    Fuel Pump Relay and pin locations? 280SE 1972 4.5L Floydf Vintage Mercedes-Benz 16 06-04-2016 02:37 PM
    ALL RELAY LOCATIONS 560SEL 123CLOCK W126 S,SE,SEC,SEL,SD,SDL Class 10 10-21-2011 10:37 PM
    P1453 AIR relay module AIR relay module in passenger-side fuse and relay module box ? Bansai W210 E-Class 5 05-31-2011 07:30 PM
    Fuse/Links/Relay Locations The Melmaan W124 E,CE,D,TD Class 7 11-27-2007 06:33 AM
    E class fuses and relay locations 1992/5 teky General Mercedes-Benz 0 06-14-2004 04:02 PM
