Narrowing down no 4th gear issues Need Help - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-08-2012, 08:05 PM Thread Starter
Date registered: Apr 2012
Vehicle: 82 300SD
I have a recently acquired 82 300SD and it does not shift into top gear. It runs about 4000RPM at 30mph so I know a gear is missing.
I have been hunting everywhere online to try and figure this out and have come up with many possible solution and am eliminating them as best I can.
I started with the possibility of a vacuum leak so I bypassed the EGR vaccum lines and tested the vacuum reading at the Modulator but it reads fine at idle. I tested the Modulator for leaks but it holds vacuum just fine.
The Kickdown button under the gas pedal is not stuck but I still need to test the solenoid.
I am going to try and readjust the gear shifter linkage next. Just to make sure everything is lined up properly.
On my ToDo list is Check kickdown solenoid, check and adjust modulator pressure. If those don't work than my next possibilities are a bad governor or possibly the K2 clutch.
This is everything I have found that could be the cause of this issue.
Have I missed anything anybody can think of? Any advice anybody can give would be greatly appreciated. Thank you in advance.
Drako155 is offline
Narrowing of the American mind? N_Jay Off-Topic 18 02-20-2012 01:25 PM
Narrowing it down. Triggerhappy W202 C-Class 1 03-29-2010 05:33 PM
Narrowing tranny leak down, need opinions CBFintheODD W210 E-Class 3 10-28-2008 11:20 AM
Gap Is Narrowing in Battleground States Jayhawk Off-Topic 5 07-25-2008 01:28 PM
Suspension noise, narrowing down possibilities Zackb951 W210 E-Class 9 10-05-2007 09:45 AM
