New 97 300d owner - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-06-2012, 03:22 PM Thread Starter
Date registered: Apr 2012
Vehicle: 97 e300 diesel running on Bio, 03 Jetta TDI, 97 Ford truck 7.3 power stroke,
New 97 300d owner
I just bought a 97 E300 diesel that has 197,000 on it and has ben run on bio diesel for the last 100K or so. I plan on running it on bio also. It is a non-turbo and had a slight knock in the top of the engine that sounds like a rod bearing but the sound is coming from the valve train. The knock goes away under load and is most pronounced when you hold the throttle at a high idle with no load on the engine. That is what is leading me to believe that it is not in the bearing or wrist pins. I also noticed the head gasket leaking coolant at the back of the head so I am tearing it down and I will chnage the head gasket. While I am tearing it down I was hoping to see an obvious sign of where the noise is coming from. At this point I have it ready to take the head bolts out but after breaking three tri squares I have ordered one made for head bolts.
So far I see nothing obvious but I was wondering if anyone else has run into this issue? I was thinking it may actually be an injector itself. I also noticed that the valve springs do not seem to very tight around the seats and I iwll need to inspect the valve guides when I get it apart. It looks very clean inside with no signs of gumming up. I did not think to visually check the oil pressure before I tore it down but at low RPM there was no noise so I dont think it is a weak oil pump but if there are known issues with them I would go the extra route to change it. I know this is a bit much for an introductory post and I will post in another section too.
Thanks in advance
Stubborn66 is offline
post #2 of 3 (permalink) Old 04-08-2012, 07:45 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld
eric242340 is offline
post #3 of 3 (permalink) Old 04-09-2012, 03:45 AM
jks2007red230's Avatar
Date registered: Feb 2012
Vehicle: 2007 Mercedes-Benz C230, 2007 Chevy Equinox, 2003 Saab 9-3 2.0t, 1996 Chevy Tahoe, 2000 Ranger R83
Welcome to Benzworld.
jks2007red230 is offline
    New 300D Owner Milo902 W123 E,CE,D,CD,TD,TE Class 12 03-17-2011 10:04 AM
    A little help for a new 83 300D owner rayceholt W123 E,CE,D,CD,TD,TE Class 7 02-13-2011 06:53 PM
    New 91 300D owner 300D-91 General Mercedes-Benz 2 04-02-2010 01:55 PM
    New Owner of '84 300D Hessian General Mercedes-Benz 2 08-07-2009 10:33 AM
    new 300d owner mb300d1983 General Mercedes-Benz 1 03-23-2009 11:16 PM
