What can you do if transmission warning light on your car - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-06-2012, 02:19 AM Thread Starter
Date registered: Apr 2012
There is a warning light on, but I don't know what does it mean. My friend said it looks like a trannsmission lighting up. And he told me that there will be a code why the light is on but I can't read it with a regular scan tool, I need to have them read at a repair shop that has a special trans code reader, such as the autosnap gd860. I search it on the google, it is really expensive.
stobe is offline
post #2 of 11 (permalink) Old 04-06-2012, 05:42 AM
Musikmann's Avatar
Quoted: 6 Post(s)
That might be a check engine light. Try to read codes with a regular scan tool.
Musikmann is offline
post #3 of 11 (permalink) Old 04-06-2012, 09:41 AM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1349 Post(s)
As far as I know transmission codes will show on OBD II scanner, just will not reset unless you have specific MB scanner.
For checking the codes in US for free you can go to AAMCO or some Autoznes do that as well. Knowing the car MY and your location would help us help you.
Welcome to the forum.
Kajtek1 is offline
post #4 of 11 (permalink) Old 04-06-2012, 11:14 PM
~BANNED~
If You Don’t Stop Driving...
If you keep driving an engine that is overheating, it can cause serious damage. The engine may start to knock (caused by detonation), which in turn can cause piston, ring and head gasket damage. As the internal parts of the engine expand from the excessive heat, clearances may be reduced to the point where metal-to-metal contact occurs. Valve stems may gall and stick, and the pistons and camshaft might scuff or seize
mark.galen is offline
post #5 of 11 (permalink) Old 04-07-2012, 12:46 PM
Kajtek1's Avatar
Forgot to add that he will not win the lottery and might become impotent
Kajtek1 is offline
post #6 of 11 (permalink) Old 04-07-2012, 01:21 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
I wonder if any car can overheat when it's driven in North or South Pole.
mbvis is offline
post #7 of 11 (permalink) Old 04-08-2012, 08:44 PM Thread Starter
ok, thanks Musikmann, but I want to know which regular scan tool can work my car? I have no regular scan tool at present.
stobe is offline
post #8 of 11 (permalink) Old 04-08-2012, 08:46 PM Thread Starter
thanks Kajtek1, I think I will do as you said.
stobe is offline
post #9 of 11 (permalink) Old 04-08-2012, 08:48 PM Thread Starter
sorry, I also wonder
stobe is offline
post #10 of 11 (permalink) Old 04-08-2012, 08:56 PM Thread Starter
thanks your remind!
stobe is offline
2005 c230 Alternator warning light and ESP warning light Oaklandish W203 C-Class 11 04-06-2013 09:57 AM
Transmission warning light Herniakey1970 V-Class 8 04-06-2008 02:01 AM
Transmission Warning Light Not Clearing kristoofar V-Class 9 08-12-2007 06:05 AM
V230 transmission warning light awdunbar V-Class 1 10-17-2004 10:33 PM
V230 Auto Transmission Warning Light buk V-Class 0 03-18-2004 08:30 AM
