How test EGR valve? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-30-2012, 12:58 AM Thread Starter
Date registered: Jul 2009
How test EGR valve?
Is there a way to test an EGR valve? I just (barely) passed CA smog with my 1990 300SE -- NO at 529 at 15 MPH just under the limit. I've replaced the catalytic converter and the oxygen sensor.
-- Roy Zider
1990 300SE 154,791 miles
15	1795	14.7	0.3	88	0.18	529
25	1863	14.9	0.1	50	0.05	106
1990 300SE
BitBucket is offline
post #2 of 2 (permalink) Old 04-01-2012, 02:15 PM
Date registered: Feb 2012
I can't recall or not but that egr should be vacuum actuated. You can unplug the vacuum line and hook up a vacuum pump to it. with the car at idle apply vacuum to the valve and see if the vacuum holds. If it holds you know the diaphragm is intact. With vacuum applied the idle should be really rough. if the idle does not get noticably worse then the passages are probably plugged up with carbon. you can take the valve off and clean the carbon out and retest it. Hope that helps
kered is offline
    EHA valve problem??? How i can test it ?? kessen W124 E,CE,D,TD Class 4 01-04-2012 04:52 AM
    EGR Valve vacuum test question soundquest W124 E,CE,D,TD Class 1 09-17-2009 09:42 PM
    breather valve test? JimAB W201 190-Class 0 05-31-2008 07:40 PM
    test drove an '85 8-valve Tom93R1 W201 190-Class 14 04-25-2007 10:45 AM
    90 300 te 4 matic test valve louzbenz904x4 W124 E,CE,D,TD Class 1 12-14-2006 06:02 AM
