W203 C240 dies in traffic - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-23-2012, 09:28 AM Thread Starter
Sick Pony's Avatar
Date registered: Mar 2012
Vehicle: 2001 C240, 2007 Mustang GT, 1989 Mustang LX50, 1972 Gran Torino Sport, 1968 Chevy II
Yesterday was the second and third time my C240 just died pulling away from a traffic light (or 4-way stop). It runs out 1st gear, then right when it SHOULD shift, the engine sputters and the dash lights up like a christmas tree, until the engine cuts off. I have checked the info panel, no malfunctions. I ran an Actron code scanner, no codes. I used a high quality battery tester, good static voltage, good standby voltage, AND the alternator seems to be (at idle) putting out proper voltage AND amperage.
HELP PLEASE!
Thank you in advance.
Sick Pony is offline
post #2 of 4 (permalink) Old 03-23-2012, 10:55 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Welcome. Please take a minute to click user cp and edit details to add your vehicle and location information as it can be helpful information when you're seeking assistance.
When this happens does it restart right away? Or do you have to wait a few minutes? On the restart is it right away or is it kind of hard to start?
What happens if you put it in W mode (starting in second gear)?
Does it matter how hard you are accelerating?
Can you get real-time values for fuel trim from your scanner? If so what are they?
You might also post this into the forum for your car (W203) instead of just this general one, which is really more for generic stuff about all things MB, not specific car issues.
Good luck!
Check Codes is offline
post #3 of 4 (permalink) Old 03-23-2012, 11:34 AM Thread Starter
Sick Pony's Avatar
Trying to answer Q's in order:
-When it dies, the started spins the engine over right away, but it takes 10-12 revolutions for the engine to fire, like fuel or spark isn't being immediately present.
-Haven't tried "W" mode. I'll try it next time.
Living in Florida, "W" mode is like heated leather
seat's... don't see needing them. For that matter
I refrain from using manual mode for concern of
excessively wearing the internal components.
-Happens when accelerating away from a traffic light or 4-way stop. Compared to my Mustangs, I am rather tame in how I pull away, but it's all relative. I'm a little sensitive to "caning" it unnecessarily.
-I have not tried scanning for real time values in fuel trim. My Actron OBD-II scanner supports that function, but it's usually home in the garage. Additionally, the placement of the OBD port under the dash puts it in my way for normal driving. I'll connect it tonight and take a little drive... What are "normal" numbers? I'll post what I see.
Thank you!
post #4 of 4 (permalink) Old 03-25-2012, 07:33 PM
Mar L. Barruel III, MBA's Avatar
Date registered: Feb 2008
Vehicle: 2005 ML500, 1999 C230 KOMPRESSOR, 1993 300E, 1964 220SE, 1994 E320, 2001 E320 4MATIC, 1991 380SEL
Check fuel pressure...may have a bad fuel filter (pressure regulator built-in) or a bad fuel pump! Fuel pressure must be at least 3.7 bar.
I'M A FACTORY-TRAINED MERCEDES-BENZ MASTER SYSTEMS TECHNICIAN, ASE (AUTOMOTIVE SERVICE OF EXCELLENCE) MASTER AUTOMOBILE TECHNICIAN, BOSCH MASTER TECHNICIAN, MECP (MOBILE ELECTRONICS CERTIFIED PROFESSIONALS) MASTER TECHNICIAN, AND A L1 ASE & BOSCH ADVANCED ENGINE PERFORMANCE SPECIALIST WITH A MASTER'S IN BUSINESS ADMINISTRATION.
Mar L. Barruel III, MBA is offline
    W203 C240 won't start riqchua W203 C-Class 11 11-06-2011 06:48 AM
    Help! -- 2006 G500 dies mysteriously in traffic doubledub G-Class 18 04-22-2009 03:20 PM
    c240 almost dies when turning dockeith11 W203 C-Class 3 07-06-2007 12:28 AM
    E430 dies in traffic bglz42 W210 E-Class 9 07-11-2006 05:41 AM
    FS: 2003 C240 (w203) – So Cal jshiuan For Sale/Wanted/Trade/Giveaway 1 03-13-2006 12:55 AM
