Check engine light after oil change - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-21-2012, 09:42 AM Thread Starter
Date registered: Nov 2010
I have a 2006 e350 and I had the oil changed at a Goodyear center, a day later the check engine light came on...Is this something I can reset myself, or do I have to take it back to have it reset?"
zenece is offline
post #2 of 2 (permalink) Old 03-21-2012, 06:47 PM
Date registered: Jul 2004
Quoted: 294 Post(s)
Probably unrelated but I wouldn't go back there anyway. You will need an OBDII code reader to read and delete the code. Of course if you don't fix the underlying problem it will probably come back. You can buy an OBDII code reader for $50 to $100 just about anywhere, and some auto parts chains such as Autozone will read the codes for free when the check engine light is on.
deanyel is offline
    Help!!! Check engine light after oil change bigp W163 M-Class 10 11-15-2010 04:29 PM
    How to change Check Engine light sensor rmalla W163 M-Class 3 10-30-2010 10:04 PM
    Check Engine Light with no change in engine - cold day macmonkey R129 SL-Class 9 12-02-2008 08:36 PM
    Just got an oil change and got a check engine light stvxenson W202 C-Class 2 10-06-2008 08:49 PM
    Check Engine light on after oil change Guest (MBNZ) W124 E,CE,D,TD Class 1 05-29-2002 06:33 PM
