2002 E320 Key Fob Battery Insert. - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-20-2012, 09:02 AM Thread Starter
sailswish's Avatar
Vehicle: 2002 E320 Silver Wagon
Hi All,
I have 2 keys. One is worn more than the other because of EDC and does not lock/unlock anymore. Batteries are still in good charge, identical voltage as the less worn fob which works flawlessly. I swapped out the battery insert with each other and the worn fob now works.
Question: there are a lot of fobs on Ebay. Can I buy one of these and just use the battery insert without having to reprogram?
THANKS!!
sailswish is offline
post #2 of 6 (permalink) Old 03-20-2012, 12:30 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
What is "battery insert"?
mbvis is offline
post #3 of 6 (permalink) Old 03-20-2012, 01:00 PM Thread Starter
sailswish's Avatar
The plastic tray that contains the two coin batteries. There doesn't seem to be any electronics on it except the terminal connectors which makes me think you swap this out.
post #4 of 6 (permalink) Old 03-20-2012, 02:09 PM
mbvis's Avatar
Quoted: 2 Post(s)
then place the two battery inserts side by side to compare them for the bending angle of every contact with batteries in, out. Where there's contact, clean it with Qtip+rubbing alcohol.
mbvis is offline
post #5 of 6 (permalink) Old 03-24-2012, 04:22 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
The stuff on ebay is only good for cosmetic case change, thats it. spend the two hundred and get a shiney new remote with key.
Peter Guenther is offline
post #6 of 6 (permalink) Old 03-24-2012, 05:15 PM
Date registered: Apr 2011
Yes, you can use the battery holder from another key fob, the electronics are inside the key fob.
MBTech001 is offline
    WTB: ashtray insert, '99 E320 kwhombre For Sale/Wanted/Trade/Giveaway 4 03-03-2011 01:01 PM
    w211 Battery Drain e320 2002 williambradley General Mercedes-Benz 1 10-29-2010 05:14 PM
    Looking for front tag insert panel for E320 wagon cphilip W124 E,CE,D,TD Class 4 12-26-2008 06:12 PM
    battery, 2002 E320 kate General Mercedes-Benz 3 04-04-2008 03:25 PM
    1995 E320 avantgarde grille insert ? ksing44 W124 E,CE,D,TD Class 1 03-20-2003 08:35 AM
