230E W124 flasher relay - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-19-2012, 02:23 PM Thread Starter
Date registered: Mar 2012
I consider myself to be fairly good with most things on my W124, however this one has me. symptoms:
Bad lamp indicator comes on but all lamps OK, 2 weeks later same thing
4 hours later left hand turn indicator flashes rapidly, check, but all indicators lamps are fine and operating. right hand turn indicator operates correctly.
Now is this a problem with the flasher relay, if so where is it located or could it be another problem?
All help gratefully received.
cannonbridgehouse is offline
    Can you please Help - Flasher Relay MercC200 W202 C-Class 2 10-11-2010 06:38 AM
    $182 for a Flasher Relay??? Hbro111 W126 S,SE,SEC,SEL,SD,SDL Class 9 07-23-2009 07:15 AM
    is the flasher relay here? (pic) sfclk C208/A208 CLK-Class 1 01-22-2009 06:06 PM
    where is flasher relay dfwdiesel W123 E,CE,D,CD,TD,TE Class 3 07-04-2004 09:58 AM
