Air Pump 91 560SEL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-19-2012, 02:01 PM Thread Starter
1_maniac's Avatar
Date registered: Nov 2009
Vehicle: '91 560SEL
Air Pump 91 560SEL
I have a '91 560SEL gas motor & the air pump bearing is starting to
make noise like the pulley bearing is on the way out. I ask if I can
just remove the belt from the air pump until I can find a replacement?
Other than emissions, will this damage the motor?
Finally, does anyone have a lead on a replacement for the air pump?
Aftermarket or MB would be fine, but cost is the issue. I would even
consider a used one that is in working condition.
Thanks in advance.
1_maniac is offline
post #2 of 2 (permalink) Old 03-22-2012, 03:27 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Your Parts Search Returned 1 Part(s)
flyboyike is offline
    560SEL Oil pump needed Ayhan W126 S,SE,SEC,SEL,SD,SDL Class 4 12-27-2010 01:03 PM
    fuel filter & pump 1989 560sel rmeyer W126 S,SE,SEC,SEL,SD,SDL Class 3 01-28-2010 06:23 PM
    560SEL Water Pump Replacement Abdullah2009 W126 S,SE,SEC,SEL,SD,SDL Class 3 05-24-2009 03:37 PM
    Fuel Pump Test on 86 560sel DAS1 W126 S,SE,SEC,SEL,SD,SDL Class 0 09-03-2004 12:16 PM
    560SEL Smog Pump Twitch W126 S,SE,SEC,SEL,SD,SDL Class 8 05-12-2004 07:28 PM
