MB E220 2006 belt - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-19-2012, 05:18 AM Thread Starter
Date registered: Mar 2012
Question MB E220 2006 belt
English is not my language so i do not know if the word is right but i try.
My transmission belt?/ timing belt? fell off and i am looking for a drawing or form to put it back on.
Is there anybody who can help me?
Pico9 is offline
post #2 of 2 (permalink) Old 03-19-2012, 06:55 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If you are talking about the belt on the front of the engine, about 25mm wide, that is commonly called the serpentine belt.
You should find a diagram in the owner's manual.
However, they don't just "fall off" so you must find the source of the problem: what caused it to come off. Common causes are a failed tensioner or idler pulley.
If you don't know how to fix it take it to a shop.
Good luck.
Check Codes is offline
    E220 CDi Drive Belt Tensioner tamrsoft W210 E-Class 3 03-12-2012 09:44 AM
    w 124 e220 belt ibrahimerican W124 E,CE,D,TD Class 1 10-24-2011 02:40 PM
    2006 CL55 AMG - Belt Tensioner fell off! Horizon1 General AMG 2 04-09-2011 02:12 PM
    E220/220E Poly V-belt diagram integrale697 W124 E,CE,D,TD Class 4 02-10-2010 04:56 PM
    E220 Cam Belt? heckflosse W124 E,CE,D,TD Class 1 02-11-2003 02:54 PM
