B200 turbo. everything turns on EXCEPT the motor - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-18-2012, 08:36 AM Thread Starter
Date registered: Mar 2012
I have a 2007 B200 turbo. In January, I got into the car one morning and turned the ignition. Everything came on except the engine. I figured it was just the cold weather. My second attempt was successful and off I went. By the beginning of March, this had become more common.
Now, the more I drive the car during the day, the more likely this problem is. I turn the ignition and everything turns on EXCEPT the engine. the lights on the dash, headlights, windows, etc. Everthing will work but the engine doesn't turn over. I'll sit and wait and after a few trys, the engine will start.
I've had a lot of problems with this car and doubt I will ever buy another Mercedes. I'm hesitant to bring it into the shop in case they tell me something that might not be true. In January, I had to bring the car in because the passenger door lock was making a machine gun noise. That cost me $500 to fix and then they said there was a problem with my brakes. Another 2k. 2 days after leaving the shop, the driver side door started making the same noise. Grrr.......
Any idea what this problem could be before I take it into the shop?
annmtz is offline
post #2 of 2 (permalink) Old 03-18-2012, 05:51 PM
Date registered: Feb 2012
I hate to be the bearer of bad news but its probably the starter. The starters are pretty common to go on the b classes. If you take it to the dealer they should be able to scan it and get a code for the starter. The bad thing about the starter is that you have to drop the engine cradle to replace it.
kered is offline
    2006 B200 non-turbo should I? biffidum W245 B-Class 24 04-08-2016 04:34 AM
    B200 Turbo Production End Alpha Centauri W245 B-Class 6 01-21-2011 08:12 PM
    2007 B200 TURBO shotgun_banjo W245 B-Class 17 06-03-2010 07:43 PM
    Witch type of motor oil for B200 Turbo? milosmeda W245 B-Class 5 06-25-2009 10:44 AM
    B200 Turbo problems! Mrshal99rshal99 General Mercedes-Benz 1 04-06-2009 06:36 AM
