engine oil leak - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-15-2012, 12:02 AM Thread Starter
Date registered: Mar 2012
Vehicle: 2007 S550 4MATIC, 2008 ML 320 CDI, 2010 ML 350 BlueTec
Smile engine oil leak
hi guys, i have a little car mechanic question to ask, please help me out
i just picked up a pre-owned star certified 2008 ML320 CDI.
After driving it for some hours, i parked my car and after a while, noticed a black pool of oil under the front of my car.
I popped the hood and saw engine oil all over the place. I took out the engine oil filter cap, and re-tightened it. For the rest of the evening, the leaking seemed to have stopped.
Next morning, i still noticed a pool of oil under my car.
Took it to the dealer.
The service advisor took a look at the car, drove it around, cleaned up the mess.
His diagnosis is that either the cap was loose, or there was spilling during adding motor oil. In either case, oil was being heated up during driving, and flowing down like water and splashing around under the hood which casued the mess. He cleaned up the mess, and said the car is fine, and the only thing that he could do more is to leave the car to him and he clean it for a couple more days, but the car is fine.
The sales admitted that while showing to me how to add motor oil when i was picking up the car, he might not have tightened the filter cap enough. (the engine compartment was clean when i saw it at the time).
I took the car home and going to monitor if there is anymore leaking for a couple of days.
Here is my question:
1) what if leaking continues?
2) I am hopeful that the leaking will stop, but i am very curious to know if the spilling and oil splashing around under the hood while driving could cause any real damage to my engine or my car?
Thanks for any input.
BraveHeart1212 is offline
post #2 of 6 (permalink) Old 03-15-2012, 12:05 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Assuming they are telling the truth about not getting the cap tight, that could be all it was. The underbody panels can collect quite a bit, then it drips out later, even after the source is stopped. Just keep an eye on it and see.
Good luck.
Check Codes is offline
post #3 of 6 (permalink) Old 03-15-2012, 12:57 AM Thread Starter
Good luck.
Ya, so my car/engine is fine right? I was really afraid that oil spilling out while the car was running/engine was hot might damage something.
Thanks for the reply.
post #4 of 6 (permalink) Old 03-15-2012, 03:10 PM
Vehicle: 1985 300SD (my first ever Mercedes)
Yes, your engine will be fine. It may need cleaning for a few more times, but it will be just fine.
mlhuggins133 is offline
post #5 of 6 (permalink) Old 03-15-2012, 03:15 PM Thread Starter
cool~how important is the cleaning? the dealer already cleaned it up yesterday once. They said further cleaning needs a couple of days. Its ok if i just ignore it right? eventually its all gonna dry up or drip down i guess?
post #6 of 6 (permalink) Old 03-15-2012, 04:08 PM
If they did a good cleaning that will be fine. You may smell the oil burning off hard to reach spots the next few days. If after a week you still smell it, have them clean it again. Yes, eventually it will be just a distant memory.
    Engine Leak SinghB88 W204 C-Class 2 01-20-2012 09:13 AM
    Engine oil leak - front pulley oil leak? southbusiness W210 E-Class 4 04-25-2009 06:41 PM
    Can engine leak air? iluvjesus W210 E-Class 4 03-04-2009 11:52 PM
    engine oil leak? k85o91 C208/A208 CLK-Class 0 06-18-2006 11:45 PM
    ENGINE OIL LEAK MOBBOSS42 W126 S,SE,SEC,SEL,SD,SDL Class 3 06-23-2004 06:24 PM
