Brake Pads for 2006 C230S - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-14-2012, 01:52 PM Thread Starter
Date registered: Mar 2011
Vehicle: Mercedes Benz C300 Sports 4matic, Year 2011
Quoted: 6 Post(s)
Unhappy Brake Pads for 2006 C230S
Hi
I have 2006 c23 sports sedan and recently after service b, the dealer asked me to change the front brake pdas at $775.
I am thinking of buying the brake pads and going to another mechanic to get installed. I hope its not a bad idea to get the brake pads installed not by the dealer bcz they charge outrageously.
another question is that what brake pads should i buy. i see there are a lot of kinds. what brake pads are the best? ceramic or metallic? the mecedes dealer said they use metallic brake pads made by mercedes. But from what i read, seems ceramic brake pads are the best. and then again what brand should I buy?
Is there anything called sensors to my brakes? Do I have to change that as well? Can any good mechanic other than mercedes apprentice can do that?
Any help would be greatly appreciated.
Thank you all very much.
debargha is offline
post #2 of 5 (permalink) Old 03-14-2012, 02:17 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Akebono pads are very popular and they come with new sensors. One reason for their popularity is reduced brake dust so your wheels stay cleaner. Myself I went with the Axxis Deluxe Plus pads, which are similar to Akebono but not quite so hard a compound. The wheels are no longer the reason I have to wash the car.
Dealers are often called "Stealers" and much for the reason you're describing.
Any decent shop can do this job but I'd recommend an MB indie, this is basic work will help you to find a good one. If they do good work for a fair price, you then know you can go back to them for other things and avoid the dealer.
Also, please click user cp and edit details to add your vehicle and location to your profile, it's useful information when you're seeking assistance.
Good luck.
Check Codes is offline
post #3 of 5 (permalink) Old 03-14-2012, 05:38 PM Thread Starter
Quoted: 6 Post(s)
Hi Codes
Thanks for the information. That helps a lot.
But how do I find MB independent mechanic in the area, I tried to google but couldnt find one.
Anyways, I added the details to the cp user, and thanks for that also.
Good day
debargha is offline
post #4 of 5 (permalink) Old 03-14-2012, 10:03 PM
Quoted: 35 Post(s)
Yelp can be useful; this is two indies in the area. There is only one review each, but that's something at least. (The third place listed is a dealer, probably the one that you referenced.)
Auto Repair Winston-Salem
Also, brakes are not terribly difficult, so it can be a good test for the shop to see how they are. Pretty much anyone should be able to do this job, so use it as a litmus test. Do they speak to you properly? Treat you well? Respect you? Answer your questions to your satisfaction? Is your car ready when they said?
If you're satisfied with the work and comfortable with the shop, you at least have found an alternative to the dealer.
Good luck.
post #5 of 5 (permalink) Old 03-15-2012, 03:31 AM
jks2007red230's Avatar
Date registered: Feb 2012
Vehicle: 2007 Mercedes-Benz C230, 2007 Chevy Equinox, 2003 Saab 9-3 2.0t, 1996 Chevy Tahoe, 2000 Ranger R83
I use the Akebono Euro Ceramic pads. Like them alot. Best of all, there is NO DUST!
jks2007red230 is offline
    Anyone replace their brake pads with aftermarket pads? I've seen some ads stating less brake dust. C Brian C208/A208 CLK-Class 20 06-14-2012 09:34 PM
    S320 1996 change Brake pads but now Brake Pads symbol on johnquantran W140 S-Class 3 01-11-2012 01:51 PM
    2006 C230S - Transmission "Valve Body" cracked niceaznguy General Mercedes-Benz 2 06-15-2010 01:55 PM
    2006 ml 350 rear brake pads mareklab The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 11-05-2007 05:16 PM
    Official Now: My original rear OEM brake pads lasted 74, 500 miles. I bought new OEM pads, a brake AC_ML W163 M-Class 2 02-07-2004 04:25 PM
