ac problems - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-12-2012, 12:53 PM Thread Starter
Date registered: May 2008
Vehicle: 1999 E300TD
ac problems
My ac compressor has stopped coming on. The compressor is not locked up because it turns freely by hand. Unlike some other peoples problem, my ac is not stuck in ec mode. My code 7 (refrigerant pressure) is 0. I am also showing 7 different fault codes. They are B1226 in car temp sensor w/blower, B1228 &B1229 heater output temp sensor, B1230 AC evap temp sensor, B1232 AC refrig pressure sensor, B1233 AC refrig temp sensor, B1234 AC sunlight sensor. Where would I even begin to figure out what the problem is, and how I should attempt to fix it. Thanks
graysilm is offline
post #2 of 3 (permalink) Old 03-12-2012, 11:37 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
I guess your car is a Mercedes-Benz but since you are posting at the general section and you don't have any models mentioned in your profile, you could give more details.
You do seem to have a lot of sensor faults, sounds unlikely that all are real (all sensors broken). But why not start from the first one and figure out the issue. If you can fix it from a loose connector, you might get others fixed too, would not harm. Otherwise continue to the next fault code.
Diesel Benz is offline
post #3 of 3 (permalink) Old 03-13-2012, 08:50 AM Thread Starter
Sorry Diesel Benz. My car is a w210 1999 E300TD. I will repost this in the W210 forum.
graysilm is offline
    fuel pump problems and running problems 90-420sel W126 S,SE,SEC,SEL,SD,SDL Class 1 11-13-2011 03:12 PM
    e320 key problems and sunroof and light problems scrappyloz W210 E-Class 11 08-02-2011 12:40 PM
    iPhone integration problems and AUX problems... nycdude777 C219 CLS-Class 3 01-27-2009 07:21 AM
    Stored 1993 S420 has fuel problems-Gives sudden starting problems-solution needed heartmd W140 S-Class 15 12-09-2007 01:45 PM
    G500 Problems - Squeaks, window problems, etc Miltona G-Class 2 10-19-2004 01:16 PM
