I require assistance with my E350 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-11-2012, 09:13 PM Thread Starter
Date registered: Mar 2012
First, i would like to express what an outstanding source of information this forum is. I've gotten answers to many of my problems without being a memeber, but i finally decided to be one.
I have a 2007 E350 4matic and Over the weekend, it was taken to a car wash in which an attendant drives it through, and upon exiting the wash, the abs light came on, and so did the check engine light. In addition, the vehicle won't shift out of 1st gear, plus the speedometer won't reflect the current speed. I could also feel the power steering and brakes not working.
I connected an obdII diagnostic code reader, and two codes came up. P0720 and P2158. I attepmted to get information on these codes, but couldn't find much that will help. I'm pretty good with cars and have all the necessary tools. Plus, i can't afford to take the car in this month, so i must find a way to address this problem.
Both codes are for speed sensors. So, should i consider the brake pads sensors as well, or is it something else?
If so, how can i replace the speed sensor and where is it located?
Thanks in advance.
saleener is offline
post #2 of 4 (permalink) Old 03-11-2012, 10:38 PM
Kajtek1's Avatar
Quoted: 1167 Post(s)
Speed sensors are total different animals than pads sensors.
Somewhere on your wheels you have a ring with notches looking like machine gears. Than next to it is a magnetic sensor that "counts" the teeth at the time to sense the speed. Those things are waterproof, but maybe strong water stream bend the brackets and the sensor is not "seeing" the teeth. Check for any visible damages and dirt on the sensor and gears. Those sensors don't fail easy, so dropping new parts would be my last remedy.
Kajtek1 is online now
post #3 of 4 (permalink) Old 03-13-2012, 01:07 AM Thread Starter
Thanks for the post. I checked all the speed sensors and cleaned them properly. But ended with the same result. The abs and esp lights remain on and power steering isn't working along with the speedometer and gear shift.
Any suggestions! I unplugged the battery for two hours and attempted to erase the error codes several times but they come back on.
saleener is offline
post #4 of 4 (permalink) Old 03-13-2012, 11:27 AM
Kajtek1's Avatar
After battery disconnect you have to recalibrate angle sensors by turning the steering wheel from one end to the other.
Try to repost the question in W211 section, but it more and more looks to me like the case for Star computer.
    Driver Assistance Package available in 2010 E350 Sedan? ohman W212 E-Class 6 11-30-2011 09:35 PM
    require : prewar mercedes raghavgupta9105 For Sale/Wanted/Trade/Giveaway 0 02-13-2009 06:56 AM
    Premium Gas Require?? sabrina W163 M-Class 15 08-13-2006 06:35 AM
    Grille which does NOT require modification... PianoProdigy R170 SLK-Class 3 06-29-2006 10:05 AM
    Profile should require "location" CQRT General Mercedes-Benz 5 05-02-2004 06:58 AM
