91 300E 2.6 stalls once the temperature goes above 90-95 deg c. - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-10-2012, 07:28 PM Thread Starter
Date registered: Oct 2011
Vehicle: 1991 300E 2.6
Unhappy 91 300E 2.6 stalls once the temperature goes above 90-95 deg c.
I NEED SOME HELP,
My wife's 91 300E 2.6 stalls once the temperature goes above 90-95 deg c.
It will crank but wont start. I have to wait until the temperature goes back down to below 80 deg c. and it will start fine with no problems.
I've replaced the fans (one of them was not working, so I replaced both), also replaced the thermostat.
I have no idea of what's wrong. I think there might be an overtemp switch that controls everything else & once it heats up, it shuts ignition and fuel pump until its back down to lower temps.
The car has 190K miles on it, and other than this stalling problem, we've never had a problem with it. This is the best car we've ever owned.
Does anybody have any idea of what it might be.
Thanks in advance
JCD
Diazcuba is offline
post #2 of 2 (permalink) Old 03-11-2012, 08:08 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Classic symptoms of a failed CPS (crankshaft position sensor). But your car is a W124 so you might check that forum, found under the sedans heading, for confirmation.
Musikmann is offline
300E starts then stalls straight away Toby's dad W124 E,CE,D,TD Class 12 01-23-2013 11:31 AM
91 300E 2.6 Stalls after temp goes up around 90-95C Diazcuba General Mercedes-Benz 0 10-01-2011 12:20 AM
1986 300E Stalls at Intersections aubs W124 E,CE,D,TD Class 6 03-12-2009 06:13 PM
1992 300E starts, but then stalls when I try to go toddcolliver W124 E,CE,D,TD Class 4 01-02-2007 01:30 AM
'88 300E stalls harrellem Benzworld Site issues forum 0 06-20-2005 12:23 PM
