Key fob issue - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-09-2012, 12:17 PM Thread Starter
Date registered: Mar 2012
Vehicle: Vauxhall Omega!!!!
Key fob issue
I have been sent a Mercedes key fob to repair, it is tapered, has two buttons, 2 batteries, is RF but has what looks like an infra red window in the end.
numbers on the PCB are 2251Y and 233.358.011F
It was also a nightmare to remove from the cover.
Anyway batteries are good but it appears to be dead, no broadcasting and the LED is not lighting. Switches are fine.
Anyway a few questions.
Do they work at 433.930?
Do they tend to blow the chips? Some fobs, notably Vauxhall Astra ones tend to fail rather than be repairable.
Do tracks tend to split?
Or through board joins snap?
captain-keyfob is offline
    78 300CD Instrument Cluster Issue + Starting Issue rob1202 W123 E,CE,D,CD,TD,TE Class 5 04-01-2013 09:39 PM
    *Photos* Help! Airmatic issue and dealer can't track down issue... WEBSRFRINMD W211 E-Class 19 04-09-2012 12:48 PM
    300SE vibration leads to trans shifting issue causing idle issue HOW? Alleskovar W126 S,SE,SEC,SEL,SD,SDL Class 2 03-09-2012 10:46 PM
    Strange Problem. A/C issue and engine cut off issue tied together 1989300se W126 S,SE,SEC,SEL,SD,SDL Class 1 04-03-2011 12:16 AM
    Radio Harness issue, Tuner issue DamianC R170 SLK-Class 1 08-28-2006 06:46 PM
