2005 C200 Diesel starting fault - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-05-2012, 10:09 AM Thread Starter
Date registered: Mar 2012
Post 2005 C200 Diesel starting fault
Hi Newbie here !!
We have a c200 diesel which has done 80k with full service history, but now occasionally when it's warm it won't start and needs to be left for 10mins, the car will then start normally.
No problems at cold, I have changed the batteries in the key fob, there are no fault codes showing at all when the fault occurs, some suggested it was an immobilser fault, locking the car with the key remote and unlocking makes no difference.
I have seen a post where someone had a similar fault and changed the crank angle sensor with no luck
Help Any ideas ??? Mark
Sunseeker1 is offline
post #2 of 2 (permalink) Old 03-05-2012, 01:25 PM
Musikmann's Avatar
Quoted: 6 Post(s)
A crankshaft position sensor might explain why yours does not start when warm. I know this is true with gasoline cars. If diesels have those too it is worth a try. They are not expensive and people say it is pretty easy to change yourself.
Musikmann is offline
c200 starting problem kojo W202 C-Class 1 06-06-2011 05:55 PM
starting problems when engine is cold c200 fjallaking W202 C-Class 32 01-14-2011 08:11 AM
Help please! C200 not starting up. MarkLim81 General Mercedes-Benz 0 01-04-2011 01:56 AM
C200 ignition fault sherpa350 General Mercedes-Benz 0 08-15-2009 01:24 AM
Fault code 6 and Car starting problems jcochrane007 W124 E,CE,D,TD Class 3 03-11-2005 04:55 AM
