Airbag connector broken - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-03-2012, 02:03 PM Thread Starter
Date registered: Mar 2012
Hi All. I have a 2001 CLK430. I had to replace the signal switch and when I started putting it all back together the black 3 wire connector that attaches to the back of the air bag broke in half.
I see the other end of the connector connects to the black spacer behind the steering wheel.
Question is how do I replace that?????
stevecbigkahuna is offline
    '02 E430 - broken coil pack connector ezdriver W210 E-Class 5 03-04-2012 06:30 PM
    Steering Wheel with Airbag - Will Non-Airbag Type Work? soldbydon W126 S,SE,SEC,SEL,SD,SDL Class 11 04-25-2009 11:22 AM
    Plastic connector that holds bulb for fog light has copper pieces broken jchumba W210 E-Class 3 12-11-2008 03:22 PM
    Cam adjuster solenoid connector broken WB9AXO R170 SLK-Class 11 03-22-2007 06:18 AM
    Airbag and multi-funcion buttons connector harb W210 E-Class 1 12-05-2004 08:20 AM
