Engine starts, idles but will not rev. - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-02-2012, 11:32 PM Thread Starter
Date registered: Sep 2011
Vehicle: 2001 clk430
HI, i have 2001 clk430 and it is as though the accelerator is not conected, the car just idles with no pedal at all.(engine check light is on) I scanned the car with my OBD2 scanner and got a PO121 code (throttle/pedal sensor/switch circuit A problem). I bought a second hand sensor (Part number A012542) and plugged it in with no change. Do i have to do a reset before the new sensor will work? or is it another problem entirely? Does any one know of a way to test the sensor as the pins are numbered in the plug housing? Any advise welcomed.
MB 430clk is offline
    HELP! Car starts fine, then idles rough, and wont take gas/rev xserve W202 C-Class 5 10-25-2009 06:56 AM
    ML 430 starts up, idles fine, but when I ..... ReBell W163 M-Class 1 09-27-2008 08:02 PM
    560 SEC hard starts hot or cold, idles high swtexmbnut W126 S,SE,SEC,SEL,SD,SDL Class 3 08-01-2008 08:08 PM
    1985 500 SEL Starts, Drives, idles...then stalls cnittle W126 S,SE,SEC,SEL,SD,SDL Class 13 07-19-2007 02:57 PM
    Car starts then barely idles, press gas & dies?? digsand W126 S,SE,SEC,SEL,SD,SDL Class 3 03-11-2004 10:28 AM
