WATER IN THE FUEL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-02-2012, 10:43 AM Thread Starter
Date registered: Mar 2012
I need an expert opinion:
CL 55 V8. If a large quantity of water was pumped into the fuel tank, and the driver was unaware and drove this vehicle:
Could enough water pass through the fuel injectors to cause engine damage ie hydrolock? Or am I correct in assuming that the water molecules could not pass through the injectors?
If water could pass through the injectors could it run long enough to do any damage?
JERSEYJOE2937 is offline
post #2 of 2 (permalink) Old 03-02-2012, 02:17 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Water likely will pass the injectors but in amount that will not become danger of hydro-lock. Still left alone can cost corrosion.
Did you stick garden hose into your tank? Or angry spouse?
Kajtek1 is online now
    WATER IN FUEL Shane Off-Topic 5 10-23-2009 11:11 AM
    WATER is the new FUEL GaryGreen General Mercedes-Benz 0 10-29-2008 06:47 AM
    What to do after water in fuel tank trojansailor R/C107 SL/SLC Class 7 07-29-2008 01:57 PM
    Water fuel Ivan820 W201 190-Class 7 05-13-2008 11:34 AM
    Water in the Fuel Col Tigwell Downunde W163 M-Class 10 06-12-2002 01:35 AM
