2006 E350 4matic, Drive Shaft clunking noise - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-02-2012, 02:55 AM Thread Starter
Date registered: Mar 2012
I have a 2006 E350 4 matic with 45K miles on it,just recently i noticed a clunk noise when i pulled away from a standing stop, usually at a stop light, it seems to be getting worse in a very short time span, i have read about the problems with flex disc's,but this sounds more solid that a rubber joint, anyone have ideas, there is no vibration while at normal speeds nor when slowing down.
OK, have had a look underneath, all Felx disc,s are fine, thre seems to be a lot of play in the drive train as a whole, theres no play in any of the forward prop shaft to the front diff, no oil leeks at any of the shaft outputs, no bad engine mounts or suspension arms etc. just a fair amount of play in the drive train as a whole, ???? maybe its the transfer case, any ideas.
u$brit is offline
    4matic front drive shaft, please help. Stinkin83 W220 S-Class 12 10-28-2014 06:27 AM
    4matic Drive-shaft Replacement? 86_230E W210 E-Class 13 08-26-2013 05:55 PM
    2006 E350 4matic malfunction on test drive! nickorciuoli General Mercedes-Benz 3 09-19-2010 11:00 AM
    2009 S550 4matic clunking noise jaris W221 S-Class 4 11-19-2009 04:20 PM
    rear axle drive side clunking noise ???? amg guy W210 E-Class 1 09-26-2005 07:58 PM
