SD Connect C4 configuration problem - Page 4 - Mercedes-Benz Forum
post #31 of 61 (permalink) Old 01-20-2013, 10:12 PM
Date registered: Jul 2005
Quoted: 1117 Post(s)
In your cal.ini file it has to set to part W. It defaults to T. If it s at part T change it to part W.
Noodles is offline
post #32 of 61 (permalink) Old 01-21-2013, 11:16 AM
Date registered: Jan 2013
I attempt to look for the file cal.ini, had no luck. I'm I suppose to use the IP address from the MUX when you click the i button it gives you a IP address?
J.A.G.Benz is offline
post #33 of 61 (permalink) Old 01-21-2013, 12:40 PM
Use the windows search feature for the cal.ini file. We have to check that first.
I have no idea on the IP address of the mux if you are basing it on a youtube video. Most of the MB SDS videos on youtube are full of incorrect info.
Noodles is offline
post #34 of 61 (permalink) Old 01-23-2013, 08:47 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Which IP address are you referring to? The mux would show you its WLAN IP address, not the LAN IP address.
Set your PC Ethernet network card for fixed IP at 172.29.127.119, subnet mask 255.255.0.0 and use sdnc to configure the SDconnect mux with the LAN cable.
Diesel Benz is offline
post #35 of 61 (permalink) Old 02-05-2013, 10:16 PM
Date registered: Feb 2013
I just bought a T30 with SDconnent c4 from China. Im getting hard time to connect network. when I connect cable to the internet my network card light up and connecting to the internet. Bat when i connect SD connect it says network cable unplugged. and no lights from back of laptop from network card. And when i connect C4 to other laptop network is working and connecting fine. I dont know what else to check.
armen61 is offline
post #36 of 61 (permalink) Old 02-11-2013, 10:34 AM Thread Starter
Lady-Merc's Avatar
Date registered: Feb 2012
Read Diesel Benz info above. You need to set your IP in Windows XP network connections first, in order to connect to your SD by wire. The same apllies to wireless connection. SD is using Static IP addresses hence you need to change that.
Lady-Merc is offline
post #37 of 61 (permalink) Old 02-11-2013, 10:58 AM
Thanks for reply. I tried static 172.29.127.119 and i tried dhcp. No luck it says network connection unplugged. I you can i can give you my teamviwer id you can check it.
armen61 is offline
post #38 of 61 (permalink) Old 02-13-2013, 04:53 PM Thread Starter
Lady-Merc's Avatar
Can you connect your laptop to any other LAN devices? Is your socket, cable OK?
post #39 of 61 (permalink) Old 06-22-2013, 02:37 PM
Date registered: Jun 2013
Connection and battery woes
@Lady-Merc - have the battery issues gone away after the connections worked or your C4 continues to burn through batteries? Can you turn it off on its panel?
I am having the same issues with connection and IP addresses and the guidance in this discussion will help as I will try them out. I have a Dell 630 with the latest version software 03/2013 and a Chinese made C4 that behaves exactly as you've described - cannot be turned off in the front panel, burns through new batteries in 5 minutes and has difficulties connecting though it can be seen by the notebook - little icon shows up unlocked on the icon bar.
I have configured the notebook for static IP 179.29.127.119 & mask 255.255.0.0. The SD icon shows number 5 with an open padlock. All the software is working including Xentry and DAS, but still need some work to get the MUX to play nice. I will now try to see the configurations required on the MUX. It has a Netgear WIFI card in it but for now I will be using the wired LAN.
I am making an adapter so I can connect an external source for 9 volts to the MUX battery contacts and not have to waste batteries while I figure this thing out. Later if it behaves I can go to batteries again.
Any further advice is very welcome.
Bluemetal is offline
post #40 of 61 (permalink) Old 06-23-2013, 10:24 AM
Original network adapter is not compatible with chanise MUX. I tryid USB to NET adapter its working fine. Only $3.00 in eBay
http://item.mobileweb.ebay.com/viewi...d=121131846878
armen61 is offline
Heater Configuration BobinOH W123 E,CE,D,CD,TD,TE Class 9 08-03-2011 12:32 AM
CEL: to connect or not to connect that is the question Clasico R170 SLK-Class 11 04-09-2010 06:43 AM
Exhaust configuration Hanleyk1 W123 E,CE,D,CD,TD,TE Class 8 03-02-2010 07:47 AM
D2B Ring Around Configuration MBSLK-AMG R170 SLK-Class 1 03-06-2009 06:35 AM
Change of the configuration ben12 W164 M-Class 5 11-05-2005 09:58 AM
