how often do you replace the key fob battery? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 02-20-2012, 05:01 PM Thread Starter
Date registered: Feb 2012
Vehicle: 2010 E350
just bought 2010 E350... have had to changed the battery 3 times in under 60 days. Might have changed once in the 2003 that I traded in. twice taken to dealer without success. Any thoughts?
kilowatts is offline
post #2 of 12 (permalink) Old 02-20-2012, 05:51 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
NEVER.
Our original ML320 sold being 13 years old with factory batteries in remotes.
We do own E300 for about 6 years and never replaced the batteries in remotes.
Kajtek1 is offline
post #3 of 12 (permalink) Old 02-20-2012, 06:01 PM
Yazz's Avatar
Over 10, just traded her in with the originals.
Yazz is offline
post #4 of 12 (permalink) Old 02-21-2012, 03:34 AM
Date registered: Jul 2010
Vehicle: 2014 CLS550 4MATIC, 2009 SL550
I just replaced them after 4 years per the on-board display warning of low battery.
geharmon is offline
post #5 of 12 (permalink) Old 02-22-2012, 09:23 AM
Musikmann's Avatar
Quoted: 6 Post(s)
3 times in 60 days is atrocious, there is something wrong with that key. Take it back to the dealer and use your new car warranty. Assuming you have a spare key, how is that behaving?
Musikmann is offline
post #6 of 12 (permalink) Old 02-25-2012, 07:46 AM
Does your car have keyless go? Get the dealer to check the build date of your key. I remember reading a bulletin about defective keys that drain the battery. I can't remember but I think it only applied to cars with keyless go though, either way get the dealer to check it out.
kered is offline
post #7 of 12 (permalink) Old 02-25-2012, 08:03 AM
Vehicle: 78 280S, 81 300SD, 82 300D, 92 300E 2.6, 90 260SE, 94 S280, 10 E300,
Quoted: 11 Post(s)
I'm on my 2nd replacement battery on the E300, the original lasted for about 5 months, the first replacement lasted for about 16 months, the second replacement was just installed 2 days ago.
78 280S W116
81 300SD W126
82 300D Euro W123
83 200 W123 (Dad's old car being resurrected)
91 190E 1.8 W201 (wife's)
92 300E 2.6 W124
90 260SE W126
94 S280 W140
10 E300 Avantgarde W212 (Dad's)
ronw123w124 is offline
post #8 of 12 (permalink) Old 02-25-2012, 11:17 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Is that a KG car? Makes a big difference, specifically if you keep keys close to the car.
Diesel Benz is offline
post #9 of 12 (permalink) Old 05-01-2013, 01:18 PM
Date registered: Nov 2012
Vehicle: 2012 E350
OK. I'm a year late but my 2012 E350 has the same issue. I had to replace both FOB batteries after only one year of service. I asked the local dealer service department but he acted like I was the only person who ever had this problems.
I've had FOB's for years on other makes (Ford, Dodge) and they last five or six years. Someone mentioned the keyless GO system but the dealer said nada. Any ideas where I could POINT the dealer to the solution? A battery life of 13 months cannot be normal.
autobahnfan is offline
post #10 of 12 (permalink) Old 05-01-2013, 05:00 PM
Kajtek1's Avatar
If you have to point the dealer to do the job right, where do we go next?
13 months battery life makes me wonder. Would that be a constant draw - it would not last that long.
Are you sure you are not pressing the remote in your pocket?
I activated my door with the key in my pocket several times, not to mention my cellphone is turning itself on and is dialing numbers..
Kajtek1 is offline
    replace battery SLK 320 1carguy R170 SLK-Class 17 10-18-2011 03:35 PM
    How to replace key fob battery ? Toyboy C208/A208 CLK-Class 1 11-23-2005 06:37 PM
    Key Fob, does it have a battery HOW DO YOU REPLACE IT??... jaybro W202 C36 AMG, C43 AMG 1 06-05-2003 05:03 PM
    How to replace battery? mkb W163 M-Class 3 02-15-2003 07:31 PM
    Should I replace my car battery in a 4 yr old CLK? mikeyCLK C208/A208 CLK-Class 4 01-16-2003 09:52 AM
