e320 blower troubleshooting - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-19-2012, 07:20 AM Thread Starter
I have a 2002 E320 and a blower motor problem that is driving me crazy.
Started with intermittent blower operation. Finally no blower operation.
Then, after taking the covers down and driving it for a week or so, the motor came on full speed, and couldn't be adjusted. It kept running after the car was turned off, and I had to disconnect the ground wire going to the regulator to stop it.
Ok...regulator problem, right? Bought a new one, and it still didn't work.
Bought a new motor, because the motor would not run out of the car when I applied 12 v direct to the motor.
Still doesn't work with new regulator and motor.
I even tried swapping out the control unit, no improvement. Fuses all check out ok.
I have 12+ volts at the connections at the blower.
Are there any diagnostics I can perform to see what is going on? Is there a relay somewhere that could be causing this problem.
Thanks for any, and I mean ANY, help you can provide.
Ron Bruno is offline
    e320 blower / regulator troubleshooting Avenue D W124 E,CE,D,TD Class 14 10-24-2013 11:56 AM
    Wiring diagram search for heater blower motor short troubleshooting RhinoF18 W123 E,CE,D,CD,TD,TE Class 3 06-07-2011 06:01 AM
    W124 E320 Convertible troubleshooting 95e320cab W124 E,CE,D,TD Class 1 05-02-2011 10:10 AM
    E320 Blower fan Paul Sidhu Audio & Telematics Forum 1 10-23-2007 07:03 AM
    Troubleshooting 94 E320.... joelm777 W124 E,CE,D,TD Class 7 01-20-2003 09:51 AM
