Did I miss anything? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-17-2012, 06:01 PM Thread Starter
Date registered: Nov 2003
Vehicle: 2004 CLK320
Quoted: 5 Post(s)
My 2004 CLK320 has over 160k miles now. It still drives great. It has been well-maintained both mechanically and in the exterior.
In the course of the last 12 montihs, I have replaced the ATF, motor oil, coolant, water pump, brake fluid, air filter, pollen filter, fuel filter,spark plugs. I also did an alignment a few months ago.
Anything else I should do?
mis3 is offline
post #2 of 9 (permalink) Old 02-17-2012, 06:37 PM
Logikal's Avatar
Date registered: Dec 2011
Vehicle: 1974 450SL; 2009 CLS550
Flush and fill the Headlight fluid.
Logikal is offline
post #3 of 9 (permalink) Old 02-17-2012, 06:57 PM
Kajtek1's Avatar
Quoted: 1198 Post(s)
Change the tire air from winter to summer blend?
The list of checking jobs is in the service manual. If you don't have one, you should be able to get it in digital form from MBUSA.
Kajtek1 is offline
post #4 of 9 (permalink) Old 02-17-2012, 07:51 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
Are the spark plug wires original?
Mike
Michael Pillay is offline
post #5 of 9 (permalink) Old 02-17-2012, 09:04 PM Thread Starter
Quoted: 5 Post(s)
Yes, never been changed.
Do these wires have to be changed? I recalled I had to change them one time with my Honda. I had difficulty to start the car when it rained, something to do with the insulation.
mis3 is offline
post #6 of 9 (permalink) Old 02-18-2012, 07:20 AM
Quoted: 86 Post(s)
I change my wires every 100K miles. I dont know if it needs it or not at this time but the cost of changing them every 100K vs possible problems-well, it makes sense for me to change them at this time. You can use a 17mm open end wrench to pop the wire off the spark plug. The other end of the wire can be a pain sometime. It seems like one of the wires always is stubborn coming off the ignition unit. A bit of twisting and pulling and you will be able to remove it though. Autohausaz has the wires.
Mike
post #7 of 9 (permalink) Old 02-18-2012, 07:23 AM
Quoted: 86 Post(s)
Take a look at this
BenzWerks's Channel - YouTube
Mike
post #8 of 9 (permalink) Old 02-18-2012, 07:57 AM Thread Starter
Quoted: 5 Post(s)
Do these plug wires get bad over the years? What are the symptoms?
mis3 is offline
post #9 of 9 (permalink) Old 02-18-2012, 08:35 AM
Logikal's Avatar
Sputter, misfire, incomplete combustion burn resulting in rich smelling exhaust, lack of power, and when the insulation starts to go, you can have a light show at night from arcing.
Logikal is offline
    I miss my CLK 430, but........ TennisGuy C208/A208 CLK-Class 15 10-09-2010 10:45 PM
    I have a miss in my 91 300 CE.... Bruce R. W124 E,CE,D,TD Class 15 07-19-2010 03:39 PM
    What Else Did We Miss Out On? Qubes Off-Topic 28 04-25-2010 11:21 PM
    Miss Universe and Miss USA tour Guantanamo DP Off-Topic 7 05-02-2009 10:04 AM
    I miss my 116!!!!!!!!! gregdeklerk W116 S, SE, SEL, SD Class 10 12-07-2006 07:11 AM
