Fuel Injectors 2000 ml 320 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-16-2012, 06:12 PM Thread Starter
Date registered: Feb 2012
I'm having problems with losing pulse to the Fuel Injectors on the drivers side of the engine. I get pulse when I first start the car then I lose pulse less than a minute later. When I first got the car I got a code for bad Quad driver and bad ECU. I have replaced the ECU (had it programed, returned it thinking it was bad, got another one and the same thing)................. So now I am wondering if the Cam Sensor sends signal to the ECU to run the Fuel Injectors, so maybe I have a bad Cam Sensor? What do you guys think?
burgiedanny is offline
post #2 of 2 (permalink) Old 02-16-2012, 09:10 PM
Kajtek1's Avatar
Quoted: 1168 Post(s)
I THINK you should take the car to shop with STAR computer for diagnosis.
Good luck
Kajtek1 is online now
    1997 S500 No Fuel at Injectors (fuel pumps already replaced) dleroux W140 S-Class 11 03-24-2012 04:46 AM
    Fuel System Service Procedure - Fuel Distro, Lines and Injectors BenzHacker R/C107 SL/SLC Class 10 03-29-2010 05:36 AM
    Jumped fuel relay gets fuel to injectors!Still not starting! Distributor Plunger? salthepal W124 E,CE,D,TD Class 2 10-08-2008 04:24 PM
    bad fuel? problem with fuel injectors? tmpleton88 W203 C-Class 5 08-08-2007 05:26 PM
    280E: Fuel to Cold Start Injector, but not to main injectors - Fuel Press. Regulator? or other?? GermanCarNut W123 E,CE,D,CD,TD,TE Class 0 01-25-2004 04:12 PM
