crank but no start - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-16-2012, 01:13 AM Thread Starter
Date registered: Feb 2012
Post crank but no start
I have an 92 se 300 (been driving like a dream to of late). She been acting funny cutting off at ramdom time then start back up except for this last time. It will crank but no start. thinking its he fuel pump but also think it could be ignition
coil. ANY IDEAS please!!
robsworks is offline
post #2 of 5 (permalink) Old 02-16-2012, 02:53 AM
Date registered: Jun 2011
Quoted: 84 Post(s)
you definitely have 2 good possibilities. Maybe check the fuel pump relay too? Should be behind the battery under a black plastic cover from what I've read. Also you'll probably want to make sure you're getting spark from all the plugs. Since they're cheap I'd probably do those anyways if you don't know when they were last done.
w126Sam is offline
post #3 of 5 (permalink) Old 02-17-2012, 09:51 AM Thread Starter
What's the resistance suppose to be for the ignition coil on this car for the main
post #4 of 5 (permalink) Old 02-18-2012, 04:14 AM
Disley's Avatar
Date registered: Jul 2011
Vehicle: Mercedes W124
Quoted: 598 Post(s)
Check the OVP.
Disley is offline
post #5 of 5 (permalink) Old 02-20-2012, 01:06 AM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Possible to be clogged fuel filter, just finally got enough to fill up, unless you know they are dead fresh. I am not familiar with location and access on your car but most are easy and cheap to get to.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
    My car won't start nor CRANK. amoka W210 E-Class 2 12-14-2011 01:16 AM
    No start, no crank. Could it be the ECU? crdnlsgrl W163 M-Class 84 03-28-2011 05:38 PM
    Diagnosing cold-start double-crank: cold start valve symptoms? janos_z W126 S,SE,SEC,SEL,SD,SDL Class 5 04-29-2010 04:49 PM
    Will crank bit no start JayBenz W163 M-Class 0 09-12-2009 10:08 AM
    crank crank no start.. Riverad W163 M-Class 10 05-18-2009 02:22 PM
