Revisit EIS and the greenkey - is Peter Guenther in theHouse? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-14-2012, 08:30 AM Thread Starter
jnash's Avatar
Date registered: Apr 2005
Vehicle: 2003 S55 AMG
Quoted: 29 Post(s)
I have read the more recent policy on how MBUSA requires the EIS be precoded with the VIN# at the distribution center before the dealership install them. And I understand why for security reasons they track modules and keys in the database and why they only want the dealer to install.
My EIS has internally failed on the K-line and cannot communicate with STAR. I need it to in order to perform an upgrade from keylessGo “Card” to KeylessGO “Key” and thus communicate with an upgraded KeylessGo Key module that I have ready to install.
I have a brand new EIS with a valid part number that is one part number prior to the most recent rev (that is "old stock") prior to the most recent EIS's p/n that are precoded with the VIN. This means that this older stock EIS should be programmable in STAR to replace the broken K-line EIS I current have installed and resolve this coms problem.
EPC states that for this EIS part number; “to use up old stock first" before ordering the newer EIS for customers.
So, what I think I need to do is order a new KeylessGo Key and when it arrives, ask the dealership to install my new (previous rev) EIS since they are the only ones who would access to the Green Key to program it.
I am right in thinking this? When I order a new key and it's known that the EIS is being swapped out too (old stock version) that a Green Key would also be made available? I guess it’s a question to ask the dealership.
I would like to talk to Peter Guenther since he has the 8 pages on security from the Service manual. Peter? Can you be kind enough to please call me? 713 628 0713
Anyone have any suggestions / comments on how to proceed?
Cheers
Jim
2003 S55
K&Ns, 80mm TB, NPI headers, X-pipe / 3in pipes, Kleemann Cams & 168mm Pulley, ECU & TCU tune. 550cc injectors, Meziere WP136S SC pump. UPD SC pulley & SC belt wrap, Alum idler pulley set. Fuel rail loop, LFR7AIX plugs, NPI heat exchanger, -10C mod, shift paddles, TeleAid removed.
Lowering links (1.5" front, 1" rear), 18x9.5+35 offset rims, clear side markers, KG Key retrofit, H/W Valentine1, BT phone, BT AUX, laser jam, upgraded fans in seat backs, inline ABC mag filter.
jnash is offline
post #2 of 2 (permalink) Old 03-05-2012, 07:22 PM Thread Starter
jnash's Avatar
Quoted: 29 Post(s)
never mind, i replaced my EIS switch - all is well
2003 S55
jnash is offline
    Seems about time to revisit this classic... Check Codes W210 E-Class 39 10-06-2011 08:39 AM
    let's revisit the economy mzsmbs Off-Topic 39 08-31-2005 06:26 PM
    Revisit of the Kick-down Switch performancenut W126 S,SE,SEC,SEL,SD,SDL Class 7 09-21-2004 08:32 PM
    Revisit floor plate sthu W163 M-Class 4 10-22-2002 09:34 PM
    Extended Warranty Revisit... MikeT W163 M-Class 15 01-01-2002 03:54 PM
