ML 320 engine smoke..... - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-13-2012, 10:42 AM Thread Starter
Date registered: Feb 2012
i noticed that while starting cold engine it smokes mixed colored from the exhaust, dark bule + white + black, this happens very rarely, not every day, sometimes it smokes when i do kickdown, but when i do this again it does not smoke any more, it some only once, at the first starting in the morning, or at the moment of kickdown, but very rarely. what do you think about this? engine oil is at max, i am checking it every day and after changing oil i have run almost 600 miles, and the engine oil level is at the same possition as it was after changing it.
EBR100 is offline
post #2 of 5 (permalink) Old 02-13-2012, 11:02 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 410 Post(s)
Where are you?
Please fill in your profile with User CP ^^ showing model/year/location as this often helps with forum answers. Also find your model forum (W163?) and post your questions there, as folks with your car will be more knowlegable about typical faults.
If you're not consuming engine oil, I would not be too concerned. Some of the white exhaust will be water vapour condensing to steam in cold air, which is normal on a cold start.
keyhole is offline
post #3 of 5 (permalink) Old 02-13-2012, 11:04 AM
Logikal's Avatar
Date registered: Dec 2011
Vehicle: 1974 450SL; 2009 CLS550
Sounds as though a head gasket is on its way out but that would not be the cause of the black smoke. Black fuel is excess fuel, white is coolant, and blue is oil. As the vehicle sits overnight a slight amount of oil will work its way into the ring gaps and will sit overnight until start up. Once the vehicle is started then the excess oil is burnt off causing the smoke on start up. After the vehicle obtains operating temperature, the metals expand causing the leak to seal up.
Logikal is offline
post #4 of 5 (permalink) Old 02-13-2012, 12:44 PM
keyhole's Avatar
Quoted: 410 Post(s)
+1 ^
Very logical reply, which could be the situation here. I have also realized that 600 miles is too few to check the oil level.
keyhole is offline
post #5 of 5 (permalink) Old 02-13-2012, 01:15 PM Thread Starter
i have no idea about this, it smokes sometimes, very rarely, smoke is mixed color, not blue, black or white, when it smokes once, after that it wont smoke any more.
EBR100 is offline
Engine Smoke Near Turbo scmadman94 W123 E,CE,D,CD,TD,TE Class 5 08-25-2011 11:22 PM
smoke from rear of engine... vip-ucf W140 S-Class 2 07-26-2010 07:16 AM
Smoke billows from engine?? maxixe W126 S,SE,SEC,SEL,SD,SDL Class 2 12-30-2009 06:32 PM
help 108 smoke rear of engine bay mxmegansdad V-Class 7 03-04-2009 02:53 AM
Engine Smoke KCNick W126 S,SE,SEC,SEL,SD,SDL Class 2 03-21-2007 11:07 PM
