1999 ML 320 Seconday Air Injection Valves - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-12-2012, 07:30 AM Thread Starter
Date registered: Feb 2012
Vehicle: 1999 ML320
Hi Eveyone,
I'm new to the forum so I hope I'm posting this quation in the right spot.
I just pirchased this vehicle and I have fixed everything that needed fixing except the Code for the Seconday Air Injecting system.
I have removed the entire system and I found a ton of carbon build up I replaced the cross over valve and all the vaccum lines they were all in bad shape.
Thye motor is fine it runs just like it should but the reed valves under the vacumm valves are in rough shaoe I have tried soaking and claeaning them up, but I have read all the posts on these two valves on the forum and one thing remains constant. The reed valves must lay flat and now matter what I do they are both opened about an 1/8 of inch.
Does any one know where I can just buy just the replacement valves and not the entire unit $217.00 each. The vacumm modlues are fine the diaphrams are work fine just need the valeves them selves.
uss1814 is offline
    PO410 CEL. How to clean Air injection valves & such on 55 Big Dogger W163 M-Class 0 05-11-2011 08:56 AM
    W123 wagon Euro hitch! and seconday fuel tank konradjk For Sale/Wanted/Trade/Giveaway 4 03-28-2009 05:00 AM
    Seconday Battery?? aqua_life General Mercedes-Benz 6 09-19-2008 06:53 AM
    Seconday Hood Latch problem xchnges W203 C-Class 0 06-15-2008 08:04 AM
    Fuel injection pump 1999 e 300dt Rex s General Mercedes-Benz 1 09-27-2006 02:29 PM
