ML320 power steering pump R&R - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-11-2012, 01:25 PM Thread Starter
Date registered: Feb 2012
Smile ML320 power steering pump R&R
Hi Folks,
I'm in the middle of the replacement of a power steering pump and reservoir on a 2000 ML320 and have run into a small problem...after I had removed the four bolts attaching the pump and bracket to the block, I began to remove the pump and noticed 2 thin washers or shims fell out. The area around the pump was covered with oil and dirt from the p/s leak and I didn't notice exactly where they came from. I have searched various forums and found several exploded diagrams of the pump and it's parts, but have not found any reference to these "shims". I want to be precise on the install and was wondering if anyone has info. on this issue. I don't have access to a factory shop manual...thanks for any help
Ratrodcentral is offline
    FS: 2007 CL550 power steering pump (ABC pump) Streetglower For Sale/Wanted/Trade/Giveaway 2 11-13-2011 05:54 PM
    ML320 2000 POWER STEERING PUMP INSTALLATION beniza Audio & Telematics Forum 0 04-19-2011 05:49 AM
    Wanted: 2000 ML320 Power Steering Pump LongW8 For Sale/Wanted/Trade/Giveaway 0 02-25-2011 10:01 AM
    Power Steering Pump vs. Hydraulic Suspension Pump jdg15 W126 S,SE,SEC,SEL,SD,SDL Class 9 10-04-2010 11:20 PM
    92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 05:58 PM
