Interchanging rims from E to C class - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-10-2012, 03:23 PM Thread Starter
Date registered: Jan 2012
Vehicle: 2001 C320 sport
Question Interchanging rims from E to C class
Can anyone confirm if rims from 2003 E320 will fit 2001 C320. the width and offset are different.
E 8x16 / 39 offset
C7x16 / 37 offset
dave334 is offline
post #2 of 3 (permalink) Old 02-10-2012, 03:51 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Yes ... with two caveats.
First, you'll have to run the stock C-size tire; the new wheel's inside edge will be about 1/3" closer to the suspension, so if you mount a wider tire, it will overhang more than that. You might get away with a 10mm wider tire, but that's probably it.
Second, you will have to use custom lug bolts, because the W211 wheel uses a 14M lug bolt with an R14 ball seat, and your W202 uses a 12M lug bolt with an R12 ball seat.
The proper lug bolt will be a R14x12Mx1.5x {26mm or 28mm length, whichever you can find}. usually has them for the best price.
Also, please click user cp and edit details to add your vehicle and location to your profile, it's often useful information when you're seeking assistance. And note that this general forum is, well, general. For more specific stuff about your particular model, slide down the forum page until you see the W202 sub-forum in the sedans section.
Good luck and post pics.
Check Codes is offline
post #3 of 3 (permalink) Old 02-12-2012, 06:33 PM Thread Starter
Thanks for your help and knowledge. I haven't purchased the wheels yet, but will let you know how it works out. Also thanks for the push to update my profile.
dave334 is offline
    Quick question on steering wheel interchanging W123 and W126 cheapold280ce W123 E,CE,D,CD,TD,TE Class 5 03-29-2010 01:55 PM
    Lookng For Rims 15' From 94 95 W124 Stock Rims Or C Class 15 Same Stile Anri_300D Turbo 85 For Sale/Wanted/Trade/Giveaway 1 04-07-2007 03:08 PM
    Trade chrome AMG G class rims for black Brabus rims smalk For Sale/Wanted/Trade/Giveaway 0 10-12-2005 12:07 PM
    Interchanging 83 and 84 SEC engines Guest (MBNZ) General Mercedes-Benz 6 07-27-2002 05:31 AM
    450sel parts interchanging Guest (MBNZ) General Mercedes-Benz 4 11-06-2000 06:21 PM
