problems w/ high beams and other questions - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-08-2012, 06:56 AM Thread Starter
Date registered: Feb 2012
Vehicle: 2004 S500 4Matic
The high beams worked on my '93 400SEL a few days ago, but when I put the blinker multi control to the high beam position, the lights go out. I was able to pull and hold for highs, but that ended as well - is it the micro switch in the column, anyone have similar issues?
I'm just curious about the headlight washers - is there a knob somewhere that I can't find or does it do it automatically when I do the windshield?
I've got that driver side condensation between the two panes issue as well - I think I'll take the door apart and take the glass and open it up, reseal it, suck it together with a shop vac and inject nitrogen. I'll keep you all informed (I was a diesel mechanic in the air force whilst in Deutschland many moons ago!)
Someone once told me that the mechanic guys working on cars are not rocket scientists - I took that advice and ran with it - I like to work on the mechanical things myself and save some dinero.
froschjagd is offline
    High Beams Flasher doesn't work but high beams do... doctorkaligari R170 SLK-Class 8 04-08-2013 06:34 AM
    2000 clk430 wiring harness to use both fog and high beams with low beams? 034klc C208/A208 CLK-Class 0 12-16-2010 12:11 PM
    New bulbs for my AMG fog lamps, Xenon low beams, and Halogen high beams. lynns R129 SL-Class 17 01-16-2010 03:54 PM
    Electrical Problems, Startup, Stereo, High Beams... realog W202 C-Class 10 10-09-2008 12:07 PM
    Birger, I got it to work! Bi-Xenon high beams & halogens high beams!!... Drew W163 M-Class 15 06-11-2002 08:00 PM
