Knocking noise on bottom - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-01-2012, 12:05 PM Thread Starter
Date registered: Feb 2011
Vehicle: 2000 E320
Quoted: 2 Post(s)
How much is it to fix a sway bar/stabilizing link - parts and labor? I think the quote I got was $103.
The mechanic looked at it and told me that was the problem when I told him that my car was making knocking noises on the bottom especially when I go over bumps.
2000BenzOwner is offline
post #2 of 7 (permalink) Old 02-01-2012, 12:13 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
If bottom of car = bottom of engine then it might be what your mechanic said.
If bottom of car = bottom of middle of the car then it's the catalytic converter. 10-year-old E-class got that notorious symptom aka rattling cat, louder knocking when car's hot. $500-$1000 to replace with an approved cat in California. If the steering wheel vibrates at idle in Drive at stop sign then your engine mounts are going bad which can worsen the knocking. If you can hear the knocking when not going over bumps then it's definitely that catalytic converter. There are two of them, find out which one.
mbvis is offline
post #3 of 7 (permalink) Old 02-01-2012, 12:18 PM Thread Starter
Vehicle: 2000 E320
Quoted: 2 Post(s)
I think it's towards the front. I checked with Mercedes dealer and they said it was around $500 to fix sway/stabilizer links. Could there be that much of a price difference between an independent shop and Mercedes? Do I need to go to a mercedes specialist for it?
post #4 of 7 (permalink) Old 02-01-2012, 12:22 PM
Date registered: Jan 2012
Vehicle: 92 400se, 01 ml320, 83 280SL, 79 6.9, 72 300sel 3.5, et al
the sway bar links front are easy for a shop to fix . aesier on a hoist about a half hour or less ea. a good indie can do it in less time. the parts cost around 17.00 ea even less from non dealer
Seize the Day
cronix1 is offline
post #5 of 7 (permalink) Old 02-01-2012, 12:27 PM Thread Starter
Vehicle: 2000 E320
Quoted: 2 Post(s)
special Mercedes parts for sway, stabilizer links?
I wonder, do you need specific Mercedes parts for sway, stabilizer links? If you do, I will have to ask the independent shop about that.
post #6 of 7 (permalink) Old 02-01-2012, 12:29 PM Thread Starter
Vehicle: 2000 E320
Quoted: 2 Post(s)
so is the $103 quote pretty good, or can I get it done for less? to fix the sway, stabilizing links.
post #7 of 7 (permalink) Old 02-01-2012, 12:51 PM
Date registered: Jun 2008
Vehicle: 2008 GL 320, 2012 BMW X1, 1995 Volvo 855T, 2008 Outback
Probably the only way to go cheaper is to replace them yourself. $103 is very reasonable.
Somewhat disillusioned...
This is a great driver's car, except for the comand center and lack of gauges.
The little gremlins come and go at will.
klausc is offline
Knocking Noise jerome8283 W211 E-Class 1 08-11-2010 07:40 PM
knocking noise under the car... pinoyk20 W210 E50 AMG, E55 AMG 4 05-10-2009 10:32 AM
Knocking noise in C-350 Sammie65 General Mercedes-Benz 7 09-23-2008 07:08 PM
Knocking noise? albinoni R170 SLK-Class 3 08-10-2008 11:23 PM
Knocking noise BiGbOdYbEnZ430 W210 E-Class 8 05-03-2007 03:37 PM
