1997 S420 immobilizer - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-31-2012, 05:31 AM Thread Starter
Date registered: Apr 2010
Can anyone tell me that if the key immobilizer is faulty,can that cause the engine to not crank! The igniton switch has been replaced. The shift selector switch is also replaced. The starter will function if terminals are jumped. Dealer says that the immobilizer will allow the engine to crank,but will not allow the engine to start. The remote will not operate the door locks. Thanks!!
jrysch is offline
post #2 of 6 (permalink) Old 01-31-2012, 05:57 AM Thread Starter
Update. Car will start by turning ignition on and jumping the starter terminals.
jrysch is offline
post #3 of 6 (permalink) Old 01-31-2012, 07:13 AM
Musikmann's Avatar
Quoted: 6 Post(s)
If you have a spare key try that. Otherwise replace the key battery.
Musikmann is offline
post #4 of 6 (permalink) Old 01-31-2012, 10:55 AM Thread Starter
Replaced both key batteries now the alarm system functions but it still wont start.
jrysch is offline
post #5 of 6 (permalink) Old 01-31-2012, 12:13 PM
Musikmann's Avatar
Quoted: 6 Post(s)
On my car the key batteries are not needed to start the car, only for the remote functions to work. Since you have replaced the ignition switch maybe it has something to do with the EIS (electronic ignition system). Some people have cleaned the window in the key and some part around the ignition switch that communicates with that end of the key. Another possibility is your key has gone bad and that's why I suggested you try your spare.
post #6 of 6 (permalink) Old 02-01-2012, 12:58 PM Thread Starter
Found open circuit from passenger floor panel plug to starter trigger. Violet/white wire had start signal to plug. Not continuous as white wire near passenger exhaust to starter post. Benz wanted $345.00 for the harness. Was able to rewire. Thanks for the help!!!
jrysch is offline
W202 200c 1997 Hazard/Indicator /Immobilizer fault er kevincombrink General Mercedes-Benz 0 01-27-2012 10:28 AM
Help Needed; 1997 S600 Coupe security/immobilizer w140guy W140 S-Class 3 03-15-2011 04:05 AM
Hey Hey s420 1997 mrmyles General Mercedes-Benz 2 09-22-2009 10:07 PM
1997 S420 amirtal33 General Mercedes-Benz 13 03-03-2009 03:08 PM
bought 1999 S reg s/a a class cant find immobilizer port 2 put my immobilizer key in Ali_c W168 A-Class 2 08-28-2005 12:01 PM
